:: Piontek’s vespa si
Home Forums Perso’s Projecten Piontek’s vespa si
15 berichten aan het bekijken - 61 tot 75 (van in totaal 91)
  • #487032
    piontek
      Thanks to everybody! I really appreciate.
      Anyway now the pipe is abit reduced in lenght, cuz was too much.
      I have to check if I have the vid of first start.
      However……today I was almost going to cry, because of an unexpected accident.:'(
      I’ve broke the crankshaft … even though I didn’t run it so hard.:?:boos
      On the track I used to run it with the 70 pulley and normally overtaking the 85kmh without any problems.
      I still can’t beleve it. I’ve just used this engine 3-4 times on track at maximum revs ,running very smooth.
      I’ve already disassembled the engine from the frame and the cnakshaft is broken exactly in the fly wheel fixing hole.
      I’ve known that other users on ccc, broke the crank in the same way.
      So I suggest to all…..(we have to design an appropriate crank).
      :boos:boos
      #487034
        Impressive piece of work! A real SI racer.
        #487036
        piontek
          @Edjuh
          thank you a lot;)
          Unfortunately this piece of work , had a short but intensive life:D
          #487037
          Rickieboy
            you have also i nice project
            #487049
              Very cool SI Piontek, the paint is very nice and smooth and I like the exhaust as well.
              It’s good that you made it a little shorter, it should look very cool now.
              Too bad you broke your crank though, it isn’t nice to take an engine running that smooth apart again.
              I wish you good luck with that.
              Sebastard
                Why did you fix the carter with epoxywhen you have a TIG welding instalation to weld it with?
                nice bike tough!
                #487053
                piontek
                  thank you javad, nice to hear from you again.
                  To sebastard beacause the tig welding is the best choice but at the same time you transmitt a lot of heat through the carter.
                  This causes distortions on the surfaces of the carters.
                  To avoid any of these problems I just made a little weld, also beacause the wall where I did the weld was very thin, so it’s easy to make a hole through it.
                  Than I decide to put some epoxy , just to help the weld and fill the empty points.
                  #487054
                  Sebastard
                    oke,logical awnser!
                    (i’ve worked for 7years as a TIG welder,allu&inox)
                    keep up the good work!
                    #487055
                    piontek
                      here the crap crankshaft.
                      #487056
                      piontek
                        #487057
                          Looks like crap indeed, our own simo racer Sil did had sort of the same crack in the crank. I thought that Simonini did some sort of refund on this. But since his perso takes over more then 50 pages it is hard to find the correct story on this.
                          http://vespa-ciao.nl/forums.php?m=posts&q=3133&d=0
                          The photo’s looks certainly not amusing. Hopefully this wouldn’t let you down of future progress. A few rounds on a circuit is way to little to enjoy this Si.
                          Edit: her it is. http://vespa-ciao.nl/forums.php?m=posts&q=3133&d=2250
                          #488652
                          piontek
                            hi guys!
                            Here some news.
                            I’ve started a new project, much more cheaper than the previous one.
                            The setup is this:
                            41mm DR
                            original carters
                            original crank shaft
                            1212 carb opened up till to 13mm or something more.
                            giannelli mega or leovince exhaust
                            Variomatic transmission made of polini utah and original clutch.
                            electronic ignition with lightened flywheel.
                            here a photo of the frame that I started to shape yesterday.
                            :thumb
                            #488653
                            piontek
                              later I’ll post a picture of the cleaned frame.
                              #463170
                              piontek
                                here the unfinished frame.
                                and my new flywheel lightened up to 1.1 kgs 😀
                                #463159
                                  Thats a nice emmentaler flywheel my man!
