:: Piontek’s vespa si
Home Forums Perso’s Projecten Piontek’s vespa si
15 berichten aan het bekijken - 31 tot 45 (van in totaal 91)
  • #486317
    piontek
      please speak english, I don’t understand dutch:? 😀
      #486697
      piontek
        Hi
        some news with the cylinder.
        Today after several tests, I decided to modify the exhaust port.
        As you know, the simonini exhaust port has got a sort of occlusion that doesn’t allow to
        the gases to escape correctly out of it.
        They drop against the area where it’s placed the threaded rod, that is a little bit inside the exhaust.
        In conclusion the flux is altered.
        I decided to drill the threaded rod so that it reproduce perfectly the exhaust port, to avoid that the gases bangs on it and runs continuously.
        After that I worked on the all exhaust area to make it as much as straight as possible.
        #485958
        piontek
          #486702
          piontek
            #486703
            piontek
              an inside view of the port modified.
              #486704
              piontek
                the result of this modify is a better engine response since the low revs up to the mid. renge
                The engine is more reactive and achieves much quicker the max torque.8)
                #486728
                  Looks nice, when will you start your engine 😀 ?
                  #486729
                  piontek
                    The engine is already running 😀 (to be more precise, since a year)
                    I’m just showing you all the changes that I’ve done.
                    I’ll post some other pictures, and than some vids.:thumb
                    #486750
                      So actually we were all looking at some history around here?
                      I thought you’d posted some photos of your complete Si on this forum before?
                      Or maybe I’ve seen them on ccc.it…
                      #465988
                      piontek
                        yes it’s a sort of story, I didn’t posted on ccc my works ,(I mean not a topic).. I just psted only a photo into the elaborations, even ain’t finished.
                        Here I’ll post the complete work with some vids.
                        Hope I didn’t make you sad and disappointed :con
                        #486764
                          Ofcourse not, keep on posting 😉
                          #486773
                            Indeed nice to see all the steps of improvement. For sure the vids makes me curiuos.
                            But why the hell i thought i’ve seen some photo’s before? Wasn’t your Si Black painted?
                            Or my memory is letting me down. 🙁
                            #486777
                            Sebastard
                              Piontek, non e un nome Italiano perro,
                              polski forse?
                              bello motorino amigo,complimenti!
                              #460435
                              piontek
                                Sebastard :
                                polski forse?
                                😀 Your italian is great man!
                                Anyway, yes it’s polski , I like it.
                                #460432
                                piontek
                                  Martino :
                                  You’re right Martino, You didn’t make a mistake.
                                  There are photos of my Si on ccc but there isn’t a topic such accurate like this.;)
                                  Your memory isn’t rusty, I think it’s gonna work well still for a long time:lol
