:: Piontek’s vespa si
Home Forums Perso’s Projecten Piontek’s vespa si
15 berichten aan het bekijken - 16 tot 30 (van in totaal 91)
  • #486156
    piontek
      speedbuxy :
      piontek :
      I’ve made with a 3mm steel
      This will put alot of weight to the bike, could you not better made it from aluminium?
      You’re right, the fact is , I hadn’t think about it.:D
      At the beginning I was thinking to make it with VTR or carbon fiber, but it’s quite difficult
      and I don’t have the time.
      Anyway , it’ll be a future project.
      #486157
      JayL
        Oh no man! You’re wasting a kick RV!! If you ever decide on selling the kick engine, I would gladly exchange a Malossi RV carters without kickstart with you for your RV kick carters :thumb
        #486280
        piontek
          some news.
          I’ve made a bakelite plate of 5mm that goes between the reedvalve and carters.
          I did it to increase the engine reaction at low revs.
          I’ve also modified the 0,30 reeds with boyesen method, and I got rid of the inside reed divisors.
          #486283
          piontek
            Here the engine assembled.
            I Had to build a 4mm plate to adjust the exccessive highness of the stroke. (it’s 46mm ;))
            Also due to the conrod’s lenght (90mm).
            Here a picture, when I was checking the stroke.
            #486285
              That’s a good way to loose weight off the flywheel, i’ve never thought of that, looks cool too.
              piontek
                Hy Javad! Yes It’s a good way, I’ve made the holes and also machined on the top and on the side.
                #486287
                Jarco
                  Looking sexy mate! :thumb
                  #486288
                    How heavy is your flywheel now?
                    peter139
                      Cool 46mm stroke how much real cc is that with your simonini cilinder. The idea of the flywheel is very nice
                      you re talking about an front intake manifold. What do you mean with that? Picture? i am intrested
                      Very special project! please keep this updated for us.
                      #486293
                      piontek
                        Javad :
                        To be honest, I didn’t weight it now, I just remember that originally was something around 1340 grams.
                        I think , more or less that now is quietly 850-900 grams.
                        #486292
                        piontek
                          peter139 :
                          The real cc is 83.
                          With front intake I mean this
                          In the picture aren’t shown the holes to fix the carburettor.
                          #486301
                          SjoerdCiao
                            How do you know where you can drill holes without touching the magnets?
                            You may have a drawing that you’ve signed off where you were boring? I’ll go try it with my original flywheel.
                            Greetings Sjoerd
                            #486302
                            piontek
                              I don’t have drawings of it, I’ve just made it make with the rotary table.
                              The magnets are below the wings.
                              It’s also possible to see the magnets if you have a look under the flywheel.
                              They have a different colour .
                              #486303
                              SjoerdCiao
                                How many millimeter is between the center of the hole of the flywheel and the heart of the holes, what diameter drill did you use?
                                #486305
                                peter139
                                  beste sjoerd je weer toch wel dat daar de magneten niet zitten? Gewoon even goed kijken en je ziet de magneten wel zitten.
                                  nice project ive also an lowered inlet on my reedvalve ciao and the results are awesome. You wil get alot better gas-response.
