:: Pinasco – Evo Engine Problem
Hi
I have got a Problem
I compaired the Überströmer of the Pinasco 46mm and the Polini Evo engine and the Evo engine überströmer are too Big…
can i mount them without Problems
Here Pictures
Greets Checco97
Uberstromer=Spoelpoorten?
Klopt de 46mm Pinasco heeft kleinere spoelers dan een Evolution Engine, maar monteren is geen probleem.
Iemand van het forum heeft precies dezelfde setup en dat loopt ook super
yes indeed, he means ”spoelpoorten”” /kanalen in Dutch 😉
You can mount it this way without any problem 😉
You won’t loose any Crankcase-pression, because it’s a reedvalve-controlled inlet system 😉
Yes Spoelpoorten i didn`t know the word 😉
Ok Thanks
Greets Checco97
I think that is the best solution but i am only 14 xd
Greets Checco
Age doesn’t matter right?
yes but the expierience……
Can i do That with the file??
Greets Checco97
I would say check out arvidw his perso (page 46 would be a good start)
Page -> [url]/forums.php?m=posts&q=2936&d=2450[/url]
The crankcase can be modified with a file, i wouldn’t reccoment tuning the cilinder with a file…
Maby you’d better not modify anything untill you have practiced on cheaper parts.
Yes that what i meaned Arvid i have not much practice and probabily i will destroy the cylinder :no
Greets Checco97
