:: Piet’s VCT11 Simolini Project
Home Forums Perso’s Projecten Piet’s VCT11 Simolini Project
15 berichten aan het bekijken - 121 tot 135 (van in totaal 162)
  • #281630
      Regarding the simonini clutch, does that mean you get more revs when driving away because the clutch shoes need to go further out?
      #281631
        Mike, :thumb
        Edjuh, yes I think so, will have the same function like harder clutch springs I think. The devil sticks in the detail 😀
        #281633
          Very nice detail you’ve got the cool looking stickers. 😀
          But what do you think of the Simonini exhaust? Did you tried another exhaust to cross reference the scores perhaps?
          It is not commonly known of his great performances.
          Here’s some last info from exhausttest 2011 http://www.vespa-ciao.nl/forums.php?m=posts&q=23762&d=200
          Even on a Simo engine from Zeebodem it was disappointing.
          #281772
            Martino, yesterday I tried the Simo Thunder in combination with the 19mm PHBG carb., Polini airfilter and it was frustrating.
            No rpm’s and no speed. :boos
            Today I put the calli on and removed the Polini airfilter. The different was like day and night, black and white. 😀
            But without airfilter it get too much air now I think. Does somebody know if the Malossi airfilter from RV set fits to the 19mm PHBG Polini EVO carb.?
            Hier some vids with my 47Kg test driver 😀
            #281773
              So that exhaust could definitely to the books as the worst exhaust ever made for vespa.
              And the malossi filter for rv also fits on a evo.
              #281809
                today I got the Malossi air filter 😀
                But it is with black filter foam, a red foam is ordered now.
                But even with the black filter foam it runs great on Mono. Much better than with the Polini filter.
                Some people are forcing me to use vario with that engine, so I will try vario also for comparison.
                Here a sound check with Malossi filter 😀
                #281810
                Shaker
                  sounds good :thumb, little bit high stationair though.
                  #281821
                    new style with black 5 spakers and Vario.
                    And a rev test for Hans after about 20 to 25 sec idle gas 😀
                    #281827
                      video with a little more than half gas with my test driver.
                      He had to be careful with the throttle and to put the body weight in front to keep the front wheel down. 😀
                      #281828
                      al_bundy
                        That is a big smile on his face Ralf!
                        nice project,
                        Gr Sander
                        #280416
                        tnerual
                          Amazing to see! 😉
                          #280469
                            Looks great, but only your clutch needs to be shiny:D
                            #280470
                              hahaha, the clutch bell is the rest from my former rost look. 😀
                              But I think I need a larger ratio on gearing too. At the moment it is 10,5:1.
                              #281831
                              portlock
                                If you gonna drive with variomatic, i should buy an ivano bell, you and your moped don’t want to get hurt. ^^
                                #281833
                                  oh, what is an ivano bell?
                                  Edit Jarco: The famous Ivano Bell 😀
