:: Piet’s VCT11 Simolini Project
Home Forums Perso’s Projecten Piet’s VCT11 Simolini Project
15 berichten aan het bekijken - 76 tot 90 (van in totaal 162)
  • #280680
      wuha, maybe it is to hard for me. Will stay with the old fashion one. 😀
      Hope this engine will run like expected. Painting of the frame will be finished end of April and then I can try the first test run.
      #277204
        Very sexy engine ralf can’t wait to hear it run:thumb
        #280686
        Vespa Si
          DR-flenny :
          would it be inpropiate to be jerking off on this stuff :)?
          very unapropriate.
          However, totaly understandable 😉
          Very nice work on milling the carter Ralf. Ill be following this project ^^
          #280775
            Thanks for the positive reactions. :thumb
            short update on the paint work.
            About 10 days ago I coated the frame with “roestige kleur”
            after the first day the paint started rust
            and now after some days holiday it is more rusty
            #279171
            Jarco
              Thats some nice effect you got there. :thumb
              #280776
                Nice Rat-Look 😀
                #280777
                luukciao
                  Very Nice:thumb
                  #281131
                  CiaoGutti
                    Nice engine tuning !
                    #281246
                      after nothing was finished for the Texel Tour I drove the tour with my old Tour Oma. 😉
                      But still want to have this engine running this week.
                      So everything fixed with small adjustments
                      Then I filled benzin into the tank and saw that :boos
                      Tank is leaking. All frame work for nothing. :kots
                      By the way, there was a 70er sproeier in the carb. Isn’t that too small? I fixed a 84er now, would this work or what are your recommandations?
                      #281247
                      BDW
                        DAmn,that must suck.
                        Nice engine btw
                        wha tyou can try is tank coating,its a 2 component epoxy that you poor int the tank,and fills any holes etc,also it prevents to get rust in your benzine
                        #281248
                          That to pitty ralf:(
                          And I have a 70 sproeier with a 43mm eurocilindro and polini filter.
                          I quess you have a 48mm simo, so 84 or a little bit bigger must be right with a polini filter.
                          #281249
                            That sucks man:(
                            I also have a question for you
                            which cylinder did you drove with the VCT?
                            #281250
                              yes, sucks, all the money for the frame and the painting. :'(
                              BDW, I have no experience with that 2 component epoxy. Do you have a link or some info from that?
                              Florian, my old tour Oma runs with a standard Kick block and 43mm Pinasco cylinder (cast iron, not Alu)
                              Andree, thanks. :thumb
                              #281251
                              Leovince
                                Which painting do you mean?:lol Maybe it become leaking by all the rust? You can solder it maybe?
                                #281252
                                BDW
                                  leovinc,its special paint,the paint has components in it that rust,the metal stays untouched!piet:i cant send a link right now,im internetting on my phone,but google on tank coating. Also you could send dartfreak a pm,he has used it to make his welded tank leakfree
