:: Piet’s VCT11 Simolini Project
Home Forums Perso’s Projecten Piet’s VCT11 Simolini Project
15 berichten aan het bekijken - 31 tot 45 (van in totaal 162)
  • #279354
      @Piet, nice work! 75.6mm is sufficient, my engine had quit similar play between crankshaft and crankcase.
      I see Simonini changed connecting rods again, I haven’t seen this one before. It looks beefy:)
        and the small carter enlarged
        Fits well :duivel
        #279358
        urtaget
          Looking good mate! I love to see how you mill the carter 😀
          #279367
            today the seat for the cylinder enlarged
            and fits 😀
            Then the kruk assembled and see that there need to be a 2,5mm foot gasket
            with 2,5mm gasket it also looks better on OT and outlet
            #279368
              Nice Work Ralf!=)
              Its very nice too see what you do!
              Keep up the good work:thumb
              #279369
                Very nice engine ralf:thumb
                Did you tuned that exhaust port?
                #279370
                  only the inner diameter of the outlet tube.
                  #279371
                    Wow piet, almost everything you make is done with good precision!
                    #279372
                      Piet30 :
                      Your exhaust port look a bit higher than the exhaust port of my simo 48.
                      But anyway, you understand that you not welcome om my tours anymore, because I dont allow drivers who will be faster than me:D:D
                      #279373
                        Andree, is it ok if I use a 13 carb for your tours? That also would save fuel for me. :p
                        here you can see an add pic from the exhaust port. It still has the original strcture, not grinded.
                        also made a port map ouf the outlet
                        outlet timing is about 200°
                        #279375
                          Make it a 10/7 carb and you welcome agian:D
                          But without beiing funny your exhaust port seems to be bigger so maybe the 46mm stroke version has a bigger exhaust port.
                          Im very curious how it gonna drive in combo with the evo engine:thumb
                          #279377
                          Frank80cc
                            very nice work, nice machine ^^
                            #279427
                              so, after discussion with Mofafreak and Mike from PMT I made some fine tuning on the EVO block
                              First milled the peak behind the membran case away in both carter halfs
                              Also the membran case has some potential
                              Free breathing 😀
                              #279428
                              tnerual
                                hey
                                im amazed with all that very nice precise and exclusive work!
                                But i have only one remark,on a picture of the cylinder, i Saw that the bottom of the exhaust port is lower than the top of the transfers.. I think this isn’t very good?
                                #279429
                                  mmmh, I have not modified the ports, this is original Simonini
