:: Piet’s VCT11 Simolini Project
Home Forums Perso’s Projecten Piet’s VCT11 Simolini Project
15 berichten aan het bekijken - 16 tot 30 (van in totaal 162)
  • #279340
      A brutal combination of oldtimer and a beastly engine.
      Is there enough room for mixture to travel? Or do you aim for the highly concentrated squirt:D
      Nice work ralf!
      #279341
      Jarco
        Again, nice colecction of bearings. 😀
        Just kidding, looks awesome!
        Hope to see it alive next tour season. :thumb
        #279342
        olliegasselt
          Hi Ralf ,
          nice kurbelwelle 😀
          It fit’s nice in your Evo engine !
          i keep following this sick project :thumb
          #279343
            Hey Olaf, yes the kruk looks good in that block. Thanks again to make that happen. :thumb
            Jarco, yes there are many old bearings, maybe I can rip it up for decoration and sell it.:D
            Defenitly want to ride that Ciao over the next year tour season, sure we will meet somewhere then.
            Edjuh, that will become a smooth tour racer I hope. Maybe I will need a large backpack for oil and sprit.
            tnerual, yes like Martino said, only mill a bigger inner diameter for the crank and end modification clearence. I have all equipment to to that. Next week I will start milling and keep you updated.
            #279344
            Mike
              oeh horny!(a)
              behind the scenes, i’m already bussy with the vct’11;)
              it will be some where in Juni 2011:D
              hope this “heavy machine” is ready before that date! and also reliable:D
              Mike
              #279345
                And Ralf, you know the next tour expansion exhausts aren’t allowed, only citypowers :pest
                #279346
                .-{2F4OV}-.
                  30mm citypower:?
                  #279347
                  just1991
                    Hey how many bearings do you actually have ? cos i would like to have some for a school project.
                    #279348
                      yeah, even with a 30mm CityPower should run well, maybe a double CityPower 😀
                      just1991, no Problem, I have many many of these. This are normal and C3 krukas bearings. Let me know how many you need.
                      #279170
                        just enlarged the great carter to fit the Simo kruk.
                        The diameter of kruk is about 74mm, my carter has 74,5mm now. Do you think that is big enough or should I go for some 0,1 larger? 😕
                        #279349
                        Daan777
                          Nice work.
                          Because of the heat while running, the crankshaft will expand. But the carter will expand more because of the material it’s made of. So I think this will do fine ;).
                          #279350
                            My concerns are (still) with the small space for fuel to travel….
                            #279351
                              so, enlarged to 75,6mm. Kruk turns nice now.
                              Edjuh, that is my fear also. :'(
                              #279352
                              pepko
                                Damn! thats Hot! i hope it works thoug…
                                #279353
                                b.baens
                                  that seems nice, i think this wil run good (Y)
