- Dit onderwerp bevat 161 reacties, 43 deelnemers, en is laatst bijgewerkt op 13 jaren, 12 maanden geleden door Vespa_addicted.
5 september 2011 om 18:17 #281862
was busy again with the cables and grips, with brake light switches 😀
looks modern style now
18 september 2011 om 18:12 #281952update 😀
colored the back lamp glas dark
and the last try with Malossi 9:1 before I change back to Mono again.
18 september 2011 om 19:03 #281953Hey piet,
If the brake lights work, could you pm me the circuis? Because i lost the mine -,- (had one) and i wanna build it on my home/work citta:D
18 september 2011 om 20:13 #281955Piet why change it back to mono ?
18 september 2011 om 20:51 #278533beunhaaz, ok.
Hans, 10,5 ratio is far to short, too much wheely risk, don’t like that. If the 9:1 ratio improve the character more drivable I will keep it with vario.
If not I will drive mono.28 september 2011 om 17:37 #282007update, mechanical work finished. Now my favorite electric work can start :'(
28 september 2011 om 17:41 #282008Nice Ciao!:) Only the very old headlight on a new ciao is very ugly:con
28 september 2011 om 17:58 #282009mmmh, yes looks a bit different. But that is the headlight where I fixed the RPM counter in.
Maybe I will paint the housing black.
29 september 2011 om 01:30 #282006I’ts looking really nice!
Only one question: Where did you get those “tankstickers”(don’t know if it’s the right word for it:D)?
29 september 2011 om 07:44 #281978Daan, you can get this stickers from EditionMike, our paint master 😀
Different words are possible.
see his link
29 september 2011 om 09:02 #282010But in the new type headlight, you can build the RPM meter in also?
29 september 2011 om 10:23 #282011are you sure? The rev counter is a little longer than a speed counter.
Maybe I can check that option. 😉
29 september 2011 om 10:47 #282012there’s no bottom in the new headlight. There’s only a bottom at the beginning of the headlight glass. The RPM counter will fit like a glove i think:)
6 november 2011 om 11:51 #282272yesterday my son and I made some fine adjustments on the carb. Changed from 50 to 45er secondary jet.
Also we found out that with full gas on the handle bar the carb was not opened 100%. So we adjusted the gas cable length also to full opening of carb with full gas on handle bar.And now it runs very nice for my understanding.
The only question is now, what oil mixture are you guys using on a Simo cylinder? Is it 1:30 ?
Here the last test run
also the stationary gas is fine
25 december 2011 om 18:00 #282489now I got a Mix head lamp and fixed a LED lamp with 60 single LED’s into it.
connected to a 12 V Akku what will find place under the right side cover later.
