:: Piet’s VCT11 Simolini Project
Home Forums Perso’s Projecten Piet’s VCT11 Simolini Project
15 berichten aan het bekijken - 1 tot 15 (van in totaal 162)
  • #261899
      better earlier than too late I start my VCT11 project.
      Got a old 1974 frame to start with
      Wheel covers from FonS
      and the heart, a 46mm stroke 48mm Simolini
      That should be ok to cruise the VCT11 smoothly with a long pulley vertanding.
      #279254
      b.baens
        I will follow this perso
        It wil bee a good vespa (Y)
        #279253
        tnerual
          what happened with the cilinder?
          good luck!
          #279256
            You Crazy german guy you…
            :DNice project, again:D
            #279263
              Thats looking very smooth ralf8) I also think this gona drive well for the oncoming tour year:duivel
              #279264
              Mike
                My god, You never know where to stop, right?:P
                Again an awesome project with a nice Setup!
                what about coulours?
                I’m not a Big Fan from those wheelcovers…
                have fun again!
                Mike
                #279265
                  Thanks for following my crazy plans.
                  Maybe that will be my last project.:D
                  Mike, I thought that a real toxic Yellow will be a good color. I even also don’t know if the covers will fit into the total picture. If not I can put them off and will have some 5 spaaks below.
                  Also I have ordered a Polini race saddle to get a deep seat position as well as the additional front fork dampers.
                  I’m not at home at the time but my son told me that the 46mm stroke Simo Kruk already has arrived.
                  I really can’t wait till I will be back home to mill the Evo carters for the kruk and big cylinder.:baby
                  #275517
                  tnerual
                    what happened with the cylinder sleeve?
                    #275506
                      damn, i think idiotic yelow and black wheel covers is a very good combination.
                      and b.t.w that cilinder is sick, aren`t you affraid that the sleeve wil crack or something ?
                      could be a great contender for 100km/h 😛 i gotta follow this one 😛
                      #279269
                        tnerual, the ports are a little optimized 😀
                        Some people do it like that, for example on this cylinder.Was that your question?
                        ritze, I hope it will not crack, keep your fingers crossed. 😀
                        100km/h ??? :'( I only want to swimm smoothly in the tour field with enough play room on the throttle handle.
                        #279270
                        tnerual
                          Yes, thanks that was my question. But I don’t really see why you did that?
                          Nice Project!
                          #279271
                            that enlarges the ports more than having a cylinder wall there. :thumb
                            #279335
                              update.
                              got my Polini race saddle
                              and this will bocome the place for my 12 Volt transformer for my RPM clock
                              but the best has also arrived, täädää, the 46mm Simo kruk
                              Just a little work on my milling machine and this biest will fit 😀
                              #279337
                              tnerual
                                hey!
                                nice to see this!
                                But don’t you have to adjust a lot for fitting well that crankshaft? Thanks
                                #279339
                                  If you got the right equipment it is not so much.
                                  Just a bigger diameter for de crank and with some Simonini big ends you need to wider the case as seen on the photo’s above.
                                  Realy nice work again Ralph.
