:: Piet's Sprocatti EVOLUZIONE
Home Forums Perso’s Projecten Piet's Sprocatti EVOLUZIONE
15 berichten aan het bekijken - 76 tot 90 (van in totaal 205)
  • #282753
    misterd11
      remove the bar for the carberator, and make a bar before the manifold. And make a bar sideways the cilinder. it would be a shame if this frame go to waste, by bending of the power of the engine!! This frame cant get destroyed :p
      #282754
        misterd11, I’m not sure if I understand you right.
        On the right side of the frame I will close the holes what were made for the Simo side inlet.
        Then I planed to close the front corner around the cylinder like needed for the 4 tabs Simo. Also I could make two metal sheets like painted in the pic.
        Is that what you mean? Or what would you recommend is more effective against bending?
        On the left side I need the big cut out for the inner rotor ignition.
        Do you have any recommendations for reinforcements on that side?
        #282755
        misterd11
          The side of the cylinder is like Waarom his 4taps simo ciao?. I like that idea, and it reinforces the frame good. But the bar that blocks your manifold, can’t you weld a similar bar behind the manifold?
          Uploaded with ImageShack.us
          Good luck!!
          #282756
          misterd11
            I would strengthen this part to, because I’t looks a litte bit weak!
            #282339
              short update:
              fork in blue
              and exhaust adapter finished 😀
              I know the exhaust is not good but for a start it should work. Is there any exhaust you could recommend for that engine?
              #282785
              MarcoS
                I don’t know what’s going to work, but i’m speakless =)
                And i like your engine-model on the wall :thumb
                #282786
                  thanks Marco.
                  Comming now closer to the end, some minor problems that I didn’t realize so far working on major things. 😀
                  Putting the O-rings around the cylinder pins is no big deal
                  but how the hell can I make the O-rings stay in their groove of the head during mounting the head to the cylinder?
                  This two rings always jump out of the groove short before I have them in place. :@
                  Also realized two holes in the head, one over the spark plug and one below. Any idea for what theses holes are? Maybe one is for a thermo sensor?
                  #282787
                  QuicklyHeizer
                    Ja und das 2. ist denke ich für ein Überdruckventil. (Overdrukventiel)
                    #282788
                    Vespa Ciao!
                      Put some grease on the ring. the grease will stick on the cilinder head
                      #282789
                      niemand
                        nice project :thumb
                        about the cylinder head, i think one hole is to bleed the cooling system.
                        #282790
                          1 sensor and one plug to let the fluid come out of the head(if im not mistaken. has been a verry long time since i worked on a scooter :P)
                          #282791
                          peter139
                            nice project piet!
                            #282810
                              update: Engine is finished assembled.
                              Cutted off the middle bar what was blocking the carb, now that is looking good.
                              #282812
                                When finished, you should consider wearing a parachute pack for additional stopping power.
                                #282813
                                  :D, hihihi, stopping is maybe a good point to consider.
                                  I bended the cutout edge around the ignition a little to the outside to fit the engine with ignition.
                                  Then I saw that the driving belt was not running in line with the fox clutch.
                                  Put a ca. 5mm distance between the clutch and gearbox, and it it is in line. 😉
                                  Now I’m looking for a nice area to place the ignition coil, maybe that can be an option.
                                  Also the CDI need to have a place. Would fit on the oposite side, but that is not nice to guide the cables over to the ignition coil.:((
