:: Piet's Sprocatti EVOLUZIONE
Home Forums Perso’s Projecten Piet's Sprocatti EVOLUZIONE
15 berichten aan het bekijken - 61 tot 75 (van in totaal 205)
  • #282681
      Are you going to put a jerrycan straight on top of that? 😛
      Looks awesome! I’m excited to see the running result 🙂
      #282679
        Martino, I think I will put it in Bartjee’s blue frame as it has the stiffnes tubes to the labil rear end. And also already has the fixings for the radiator.
        docs911, haha, maybe don’t need a carb, direct fuel flow from the jerrycan. :lol
        #282682
          LOL
          It wil probably run without a jet 😛
          #282255
          ktmgek
            nice engine Piet
            that must be really fast!!!
            #282683
            Crullie
              I admire your work :thumb, but i have a little question, did you use the ball-bearing for the crackshaft from Sprocatti or did you find one’s with more balls for more durability and reliability ?
              TICKLING BARN
              #282684
                Looking very impressive. Keep the workflow going!
                #282674
                  Thanks guys, hope this will run like it looks. =)
                  Crullie, yes, I used the ball bearings from the Sprocatti set. I have researched the net to find some bearings with more balls in it but couldn’t find it. All have the same number of balls in. Looks like standard for that size bearings. 😕
                  #282659
                    short update and design change 😀
                    Got this nice reinforced frame from Bartjee. Thanks again Bart, really a nice frame. :thumb
                    #279023
                    Bartjee
                      Good luck with it! 🙂
                      #282718
                        That is realy a nice base for this engine.
                        #282720
                          yes, I think so.
                          Also found some black cover plates for the wheels. To me it looks not bad combined to the frame blue. 😀
                          But the tire has wrong profile. I will look for a bigger one with race profile.
                          And I can use my CNC milled bearing triangle now
                          #282730
                          Rizla
                            Did you also changed te front suspension. Its look like its gonna be a great project. GL an HF
                            #282731
                            MarcoS
                              [And I can use my CNC milled bearing triangle now]
                              And you won’t be sorry 8)
                              #282751
                                today worked a little with the flex 😀
                                After making cut after cut and hole after hole the engine fit into the frame now.
                                But for the carb I will need to cut this nice tube away :'(
                                #282752
                                  no reinforcements under the cylinder? would it be possible? this is a bit too small i geuss..
