- Dit onderwerp bevat 78 reacties, 29 deelnemers, en is laatst bijgewerkt op 16 jaren, 11 maanden geleden door DeensTuner.
24 september 2008 om 15:59 #266323
hehehe, yes it is a carbid lamp. Calciumcarbid mixed with water will become a Gas what is burning in front of the reflector.
For the back lamp I try to get a Petroleum lamp.(a)
So no more kabels needed and no light coil.8)
cu,Ralf
2 oktober 2008 om 17:22 #266376soho, short update 😉
Last days I fixed the clutch, pulley,ignition coil, Citta cylinder haet (after some rework), a different hand bar and made some paint work on the closed inlet and the saddle fixing.
I hope that I will get the handles, brake cables and front and back lights next wekk.
cu,Ralf
2 oktober 2008 om 17:25 #266377Wow piet it looks very horny 😀
The yellow is a great colour!
2 oktober 2008 om 18:28 #266379nice colorcombo 🙂
im excited of the possibilties of your set-up
2 oktober 2008 om 18:57 #266380maybe you can make a nice oldscool exhoust with exhoustheat band
like this
this band is also available in beige
2 oktober 2008 om 22:03 #266381I’m curious at the looks of your headlight! 🙂
Nice job of the Citta cilinder head. Beter cooling is always good!
Great job Piet
3 oktober 2008 om 10:10 #266383sombrero :
maybe you can make a nice oldscool exhoust with exhoustheat bandlike this
Hey Sombrero, that’s a really cool idea:bier
Could you tell me or send me a link where I could get the beige exhaust heat band? This is a must for Ciao;)Michel, that’s what I thought, cooling as much as possibly
cu,Ralf
3 oktober 2008 om 10:38 #266384This one gives a better example of the real world
I searched for you but i cant find the link anymore, euroscooters doesnt sell it but some other shop did.
10 oktober 2008 om 14:23 #266420so, short update.;)
The exhaust heat bands are ordered
Malossi clutch springs, brake and gas cables, fuel line and filter and the headlamp were delivered yesterday and fixed now.
I only don’t have the Deko cable, no idea where to get at the moment.
In the following pics I’ve tried to find a position for the headlamp. On top of the handlebars or below or between both:?
What do you think for the position of the lamp?
That smells like a first engine run test for this weekend:rules
cu,Ralf
10 oktober 2008 om 14:51 #266421
gido-vespamy old ninja looks good;)
10 oktober 2008 om 14:59 #266422Nice
I think position 2 is the best for the lamp;)
Where have you buy that aircleaner?:?
10 oktober 2008 om 17:12 #266423wow i like your ciao 😀 and the headlight is wonderful 😀
10 oktober 2008 om 18:03 #266424VespaAvanti :
Nice
the airfilter is from a Scooter Shop named Mopshop (www.mopshop.de)
this is the link : klick airfilter
If I order some parts next time there I can order one airfilter for you too if you want.;)
cu,Ralf
10 oktober 2008 om 18:55 #266425This kind of airfilter are not very good in filtering.
A spongefilter is better Piet. Better filtering en more capacity. 😉I think your headlight will look better just in the middle of the 2 positions if that’s possible.
So under the steeringbar and just on top of the lower forkmounting.
If that’s not possible, take the first position. Much more old timer then the lower mounting
10 oktober 2008 om 19:12 #266426Piet30 :
VespaAvanti :
Nice
cu,Ralf
Oke, thanks
Maybe my own scootershop has one, I ask him tomorow:D -
