:: Piet’s Simonini 4p
Home Forums Perso’s Projecten Piet’s Simonini 4p
15 berichten aan het bekijken - 46 tot 60 (van in totaal 63)
  • #283404
      Checked the cables towards the ignition module?
      It’s best to find out where the spark or tension ends but you know this ofcourse.
      Also i see you changed your mind again from the stage 6 inlet back to the malossi inlet haha.
      #283405
        Mmmm cba frame with 4p simonini, hot stuff Ralf. The exhaust looks fat, in a good way =)
        #283406
        Citta-ciao
          I like it!=)
          #283407
          Fredzzz
            Awesome color combination + a nice engine! Good work! I’m sure your ignition problem is something small. Any luck finding the problem?
            #283432
              Thanks for the comments. :bier
              Yes, ignition seems to be ok now.
              It runs now on idle, but when I turn the throttle it stops direct.
              I have installed a 92 main jet and 48 secondary jet. The mixture screw is about 2 turns out.
              Do you have any Idea why this engine stops when the throttle valve opens? :boos
              EDIT forgot to assemble the membran. :whistle
              But without membran it was running good on idle. :haha
              Now it sounds a little better
              #283433
                Now it sounds like how it should be :thumb
                Now stop teasing us and let us see it drive!!!! 😉
                  I would also be very happy to see what this beast can do 🙂 Nice CBA!!
                  #283437
                    Thanks lightlord and Jos :thumb
                    First I will put the yellow Malossi drukveer in, then will make a drive video :baby
                    #283440
                      and here it runs :rules
                      #283441
                      Citta-ciao
                        Nicee!!=) Topspeed?:?
                        #283442
                          Sounds good and also a nice combo with a cba frame:thumb
                          #283443
                            AWESOME!!!! yeah baby speeeeeed Looks and sounds really great :thumb
                              Your neighbours must really like you 🙂
                              I think they call the CBA the nightmare of Lindlar but i love it!!!!
                              #778831
                                after long time not working on my mopeds, JuniorPiet kicked me back into the scene infecting me with his Sprocatti Citta on race track.
                                Finally I assembled my trek starter which was laying since long tome in my garage.
                                Also changed to a mor flat stuur  😆
                                #778837
                                  I need my welding helmet to look at the frame.  😎   It looks great :thumb
