- Dit onderwerp bevat 62 reacties, 24 deelnemers, en is laatst bijgewerkt op 1 jaar, 2 maanden geleden door Crullie.
20 september 2014 om 13:59 #283285
Nice! I would never have thought of coating the wheels in one piece but i must say it looks good!
CBA’s always look great nice project!
20 september 2014 om 17:57 #283286Very nice color combination PIET !!!! 🙂
I think you should coat the subframe aswel.
It’s a bit of color from the rest.Je ware pubertijd duurt je leven lang
Lightlord's Dizzy/Gypsi20 september 2014 om 18:06 #283287It’s look very cool.
22 september 2014 om 09:47 #280429I like the Candybleu color on the wheels, do you have a color number for us ?
The Neon yellow is too bright for my taste 8)Can’t wait to see the end result with that fast engine. =)
TICKLING BARN22 september 2014 om 18:36 #282762@ Crullie, I think there is no special color number for the Candy Blue. I told the coater: Candy Blue, and it looks like the pictures on this web side.
http://www.deteil.net/V4/LS_Spezialeffekte.html
@ Lightlord: you mean coating the subframe also Neon Yellow?
@ Wilk, I saw the candy blue spoke wheels on above web side. So I had a good feeling about how it look 😀
Today I got a saddle in very good condition
26 september 2014 om 22:59 #271076That sadle looks almost brandnew nice find 😉
Still i would make that subframe blue aswel so it pops just my 2 cents 😉
Lightlord's Dizzy/Gypsi27 september 2014 om 08:18 #271157ah, understand. As I like to coat my stuur also in Candy Blue I can do that together with the subframe.
In the meantime I fixed the back wheel
This is kick ass blue 😀
As I could not find a single outlet flange from Simonini I got two custome made once. One with outer diameter of 34mm for my Roost and one with 30mm outer diameter for my Simo Calibrata and Simo 100CC exhaust.
So some choices for testing.
23 december 2014 om 16:39 #283298update
new clutch bell from Lennaert
does somebody know if there is a special tool for pull off the Simo ignition flywheel?
23 december 2014 om 21:03 #283299Nice Ralf!
I think maybe you can pull the flywheel off with a ”Bosch vliegwieltrekker”.
This is the same as for yahama DT, Honda MTX enz.24 december 2014 om 07:28 #283300Supernice, reflective colors hey =)
Gele Racefrikandel24 december 2014 om 10:34 #283301Very,very nice work!!
24 december 2014 om 17:51 #283288It’s getting there cant wait to hear it tho 😛
Lightlord's Dizzy/Gypsi19 april 2015 om 14:38 #283278Thanks.
lightlord, me too 😀
Exhaust, carb, gas cable, choke…… assembled for the first try.
But it didn’t make any noise :((
I think there is no spark, so something with the ignition.
Is there something what I can adjust on the Simo ignition?
The flywheel is fixed in position with the spie on the krukas. But is there a possibility to make something wrong on the ignition assembly?19 april 2015 om 14:43 #283402Have you tested the spark yet?
Maybe the spark itself is a goner or the cable/socket ? Easy things first then turn to the more expensive types.
19 april 2015 om 14:46 #283403Yes, checked two sparks also put the ignition cable direct to the spark.
