- Dit onderwerp bevat 63 reacties, 21 deelnemers, en is laatst bijgewerkt op 12 jaren, 4 maanden geleden door Wilk1985.
27 december 2009 om 20:25 #456719
Sweet. I guess you’ll weld a fixture for the damper? but you won’t paint the thing right? You should’nt anyway because then we won’t have twin bravo’s anymore.
27 december 2009 om 20:58 #456721Looks verry nice Ralph8) had the same idea with my citta, but don’t know if i will succeed.
28 december 2009 om 18:07 #456749
.-{2F4OV}-.That will look great! I’m a little bit curious now…
28 december 2009 om 20:09 #456761Docs, I also do not know what I’m doing and if it will work:lol
Will keep you updated on the details I’ve planed.Edjuh, yes will try to weld a bracket to the frame for the damper fixing. Some people think that the damper need to be fixed in an angle to the supframe and not vertical. Need to check how I can do that.
How is your Bravo looking? Maybe I can take over some good ideas from the twin.:DSil, maybe it will look better than it drives=)
28 december 2009 om 22:21 #456774Cool upgrade! Is the damper from 2wheelparts realy a spring and damper, that would be awsome 🙂
Home made engine dyno28 december 2009 om 22:50 #456775Nice project , keep up the good work !!!
29 december 2009 om 15:02 #456781as the damper is going down, it also moves a bit backwards. i beleave i dont have enough room for that(in my SI subframe). i will follow your work8)
26 februari 2010 om 17:06 #458587today I had my first drive with the 50ccm KickSpeed in the Bravo.:D
That engine makes a lot fun to drive. Very powerfull, perfect for an Off Road Bravo.;)
Here some filmpjes:
and finished :lol
26 februari 2010 om 17:26 #458592Good looking ralph! I’m still (^&(^&&^%ing with the front wheel(no matching plates), you’re doing fine!
You have 300mm shockers right?
ps. How about a mudguard?
26 februari 2010 om 17:56 #458593Damn that looks fast for a 50cc 🙂 Very nice job, it’s starting to look good as well.
27 februari 2010 om 08:35 #458609Geil Mann, Runs nice for a 50cc!
27 februari 2010 om 18:37 #456858hehehe, I’m more than happy that this engine runs nice. Was a lot of new things to do I never have done before, only learning by reading in this forum and some tuning books.
Edjuh, the shockers are 320mm measured between middle fixing points. But this looks not so high as it is a Si sub frame:D
No idea for a mudguard 😕 Fine tuning on optical things will start now.Maybe I will paint my side covers in red.
27 februari 2010 om 21:12 #458563
.-{2F4OV}-.Sounds really nice ralf!
You must come by one time… and drive my simociao:lol
28 februari 2010 om 00:51 #458617Then we have a flying piet :D!
4 november 2013 om 15:20 #493247
Rick.That’s a very Nice bravo!
Where did you buy those awesome tires?Edit: oh zie dat het al een oud topic is:bloos
