- Dit onderwerp bevat 20 reacties, 9 deelnemers, en is laatst bijgewerkt op 17 jaren, 5 maanden geleden door Piet30.
13 oktober 2008 om 09:44 #283842
hey, just wanted to show you my new project. 😉
This is fixing a kick start engine in an old Ciao frame from 1971. I bought this frame some month ago for 30,- Euro.
And it will become a potential ZZT 09 runner:rulesFollowing some pics how far I came with that over the last weeks.:whistle
cu,Ralf
13 oktober 2008 om 09:46 #433737
n!ck*snice project
13 oktober 2008 om 09:54 #433739Good idee to come with a old-timer to the ZZT, i will be there also with the bleu old-timer.
Looks good again and succes with the kick engine.
TICKLING BARN13 oktober 2008 om 15:33 #433748so, kick system and engine is installed.
But it looks that the chain is a little bit to long. Maybe I need to cutt off 2 or 3 chain links.
What would you say? Are 2 chain links short enough?
cu,Ralf
13 oktober 2008 om 16:49 #433750First try two and check if it’s good 😉
I like the kickstart system 😛 I wanna test my Polini kickengine 😀
13 oktober 2008 om 16:51 #433751I think you neet to cut off 3 chains at least.
13 oktober 2008 om 18:34 #433753Looks nice! Maybe I’m going to put my kickengine into my oldtimer:D
13 oktober 2008 om 21:03 #433758Looks a hell of allot better then those crappy pedals everyone drives with in germany =)
20 oktober 2008 om 09:39 #433919@ Hansieb: you say it man;)
short update.
The kick system is working now. I have put in new wheels, handlebars, front and back carrier and polished the old painting.
The carriers allow a lot of capacity for the ZZT09 =)
Also the gear ratio is installed now. It is a 10,5 :1 gear with 83mm pulley and 55mm diameter clutch bell. Dat treckt noch well:D
cu,Ralf
20 oktober 2008 om 10:01 #433920Looks almost new again, nice work Ralf.
TICKLING BARN20 oktober 2008 om 10:51 #433921Nice work first german which doesnt have those stupid pedals on 🙂 but nice kick pedals!
20 oktober 2008 om 15:14 #433927hansieb :
Looks a hell of allot better then those crappy pedals everyone drives with in germany =)Nice work first german which doesnt have those stupid pedals on but nice kick pedals!
Hans…..
Get your friggin head straight!:no
Alcohol ’s bad, mkay?
20 oktober 2008 om 15:59 #433928Hey Edjuh; I know you are a oldtimer fan too.;)
What do you think about my front carrier?
20 oktober 2008 om 16:03 #433929I like it! I have one myself, but no oldtimer ciao project so I haven’t used it yet. Are you going to mount the headlight on the carrier?
20 oktober 2008 om 16:08 #433930I want to try it to see how it looks. Should not be easy to get the electrical cables to the lamp if it is in front of the carrier.
I will try it and post a pic;)
