- Dit onderwerp bevat 47 reacties, 20 deelnemers, en is laatst bijgewerkt op 14 jaren, 3 maanden geleden door erikbloemberg.
13 juli 2011 om 18:04 #488389
Jarco thanks, this will be an easy job for my milling machine.
13 juli 2011 om 18:44 #488347
Spulleke!Ralph or Ralf dont know how u write it:P
But i am also intrested in how many project’s u have now?
But still they all are very nice
Keep up the good work:D14 juli 2011 om 12:44 #488406Nice !
19 juli 2011 om 18:11 #488572hehehe Spulleke, in addition to that project I have to finish my VCT11 project and my 2 gear Grillo project.
So then, put the flywheel on my milling machine and milled 4mm off. This is exact the right thicknes to fix it into the frame.
also received a new front lamp
19 juli 2011 om 18:15 #488573
Spulleke!Is this also going to be a FINGERBREAKING MEAN MACHINE?:haha
19 juli 2011 om 18:27 #488574wuhaha, I hope not. 😀
19 juli 2011 om 18:30 #488575
Spulleke!same for u then :p(still able to get the 46mm pinasco?)
19 juli 2011 om 18:39 #488576One awesome job for the milling machine. 😀
( Wish i had one. 🙁 )Waht did you do with your bearing colection?
Now it tires your colecting? 😀Edit: I see you have some nice relaxeing toys in the background
19 juli 2011 om 19:15 #462704Spulleke, has still can order the 46mm black Pinascos. 😀
Jarco, yes this are Carrera Universal toys for relaxing in winter time. 😉
The bearing collection is still growing 😀 A good tire sometimes is usefull, you never know.
24 oktober 2011 om 19:24 #490622just bought a Leo Handmade from Sander, thanks again.
And fixed, hope this will give some power :lol
24 oktober 2011 om 19:47 #490623
erikbloembergi like youre ciao with polini 41mm lc.
my ciao runs with a evo engine and 41mm lc polini
17 december 2011 om 13:25 #491408thanks, 41mm LC on EVO carters must run like hell 😀
As JMPB had a special price for the Gianelli Fire I bought on. It looks nicer than the Leo exhaust. 🙂
but like Vertigo said, it fits not very good at the rear fixing point. I think I will make an additional bracket to get it right.
cylinder fixing may work, but I will not use it with the LC head
17 december 2011 om 13:56 #491409
AnoniemI solved the problem with my Fire with the rear fixing point by turning the shell of the muffler a bit by loosening the bolts. First loosen the bolts at the end and you are able to turn it, you may have to use some force though, worked with me.
I haven’t got a solution for the cilinder fixing point, but don’t really mind, i just put everything very tight and push the rear fixing bolt as far as possible to the front so that it can’t fall off, because that would be a nightmare.
17 december 2011 om 14:35 #491411
erikbloembergPiet30 :
thanks, 41mm LC on EVO carters must run like hell@ piet yup
19 december 2011 om 18:22 #491444Vertigo, that is a great idea.
turned the shell and nice is
