- Dit onderwerp bevat 171 reacties, 28 deelnemers, en is laatst bijgewerkt op 8 jaren, 10 maanden geleden door Piet30.
19 oktober 2015 om 17:06 #497462
It’s ALIVE!!! AWSOME:rules:rules
Lightlord's Dizzy/Gypsi19 oktober 2015 om 17:49 #497463“Sehr Schön”:@
19 oktober 2015 om 18:29 #497465Really nice!!
It was about time somebody would make an oldtimer with variotransmission!
I like it. I think you need an oldtimer style Choke lever??
24 oktober 2015 om 16:44 #497486thanks
Jos, for sure the old type shoke lever will come. I used this carb only for testing if the engine runs and if the carb is ok.
Both is nice, now I can go into more details. 😀Also made the first drive with the Italian Ciao SC, and it is running very smooth without any vibrations and great acceleration.
Top speed of 50,9 km/h is not bad for the first tour :lol
In addition I got a series 1 old type of engine for my baby blue 19″ Ciao :swinging
Looking ugly but better than nothing.
I had to reactivate my sand blast cabine to clean that stuff 😀
Jos, maybe that is the second oldtimer with variotransmission :rules
90mm oltimer vario clutch
and the first series variator with the radii in the cutouts of the cover plate and first type brass weights.
24 oktober 2015 om 18:13 #440458Nice job!!
The sandblasting really pays off and i like the origineal oldie variator!
1 november 2015 om 17:41 #497531thanks Jos, I fixed the old Ciao style choke lever now. 😀
And the old first series egnition coil.
nice powerrrrr that
on the salmon Ciao fixed the saddle and a NOS bagage drager :whistle
1 november 2015 om 18:40 #497512Sind ja beide “Hammer”:@ Keep on going:relax
1 november 2015 om 20:49 #497535Today was a beautiful day for working on a Ciao without shoes. 1st of November 🙂
Nice work on both Ciao’s!
The bagagedrager is great because you can use it to move the Ciao, instead of lifting the saddle :Thumb
20 december 2015 om 12:47 #497771Thanks Bas and Jos
today tried to repair some side covers what had cracks and missing fixing domes for the cover screws.
First cutted some good ends of fixing domes from a broken side cover in the needed length
Then fixed the new dome ends to the cover by hot staples
cutted the staple ends away, and the new dome is finished. 😀
worked also good for repairing a crack in the cover near by a fixing dome.
6 maart 2016 om 19:19 #497823Hi, can you tell me if theres just balls in the Front wheel bearing of your 19 rigid fork? Mine looks like theres a cage around them..my Front axle has a Lot of Play too…
6 maart 2016 om 21:49 #497820there were only balls in the hub, no cage around.
7 maart 2016 om 09:09 #498041Ok, i will try, Thank you
10 maart 2016 om 21:17 #498070update on the Italian puzzle 😉
and the 19″ Baby Blue 😀
11 maart 2016 om 08:36 #498071schön =)
11 maart 2016 om 10:21 #498074 -
