:: Piet30 Bravo Mofa V
Home Forums Perso’s Projecten Piet30 Bravo Mofa V
  • #261915
      just like to show my Bravo Mofa V project.
      Goal was to build it very solid and robust, that I can ride some tours with it :@
      as the Leovinci did not perform that good I changed it to an Gianelli 😀
      and first drive was not too bad
      #283679
        Bravo Ralf!
        I love the concealed trick subframe.
        #283680
        Crullie
          Nice Ralf, looking GOOD :thumb
          What is your opinion about the subframe ?? I want to buy one to but like to know how the quality is ?!
          TICKLING BARN
          #283681
            It is a very special mix between old and new 🙂
            I like the fact that the original fairings seem to fit on the subframe!
            #283682
              yes, also the rear fender fit into the subframe
              only need to drill a hole for 3rd fixing position
              @Crullie, the supframe is fantastic quality. Very well machined, all compnents fit without additional rework into it.
              I only added a slot to use different exhausts (Si, Bravo, Ciao).
              Also you can only disassemble one half of the subframe. 😀
              #283683
                Verry nice to look at, =) Good update :thumb
                #283684
                Crullie
                  Great Thanks Ralf :thumb
                  I think I order one 8)
                  And in use with different exhausts (Si, Bravo, Ciao). can’t be better !!
                  Succes :p
                  TICKLING BARN
                  #283685
                  R.Zwiers
                    Nice subframe indeed. I think i will order one later as well. Looks nice industrial 😀
                    #283686
                      That a nice subframe and it alo fits the bravo very well:thumb
