:: Piergiorgio Pagani’s – Ciao -> VCDI
Home Forums Perso’s Collecties Piergiorgio Pagani’s – Ciao -> VCDI
  • #123081
    Piergiorgio Pagani
      Hi there!
      This is my 1969’s Ciao.
      I want to celebrate the 20th anniversary of my engine that I called ‘VCDI 002’.
      I’m sure someone already knows it…
      #123656
      Piergiorgio Pagani
        #123657
        Piergiorgio Pagani
          these are the changes I've made on Piaggio's engine
          This is the prototype engine. Sorry for bad quality pictures…
          #123658
          Piergiorgio Pagani
            The ultimate engine's test:
            In another test, with the right carburation, it has runs at 16200 rpm with the wheel free.
            A special thanks to vespa-ciao.nl and Wilk1985 for giving me the opportunity to share my memories!
            #123659
            IJskonijn
              Do I read this right? 13.3HP??? =)=)
              This is some real craftsmanship!
              #123661
              AA-T
                That's some good engine performance!
                What cilinder are you using? The 47mm deps?
                And how did you make the changes on the engine; welding or is it cnc milled?
                #123662
                Tiesman1986
                  Nice bike !
                  Do you have more pics of the build off ? 😀
                  #123332
                    Very intereresting project :thumb 🙂 Funny to see you still keep the project that you finished so long ago.
                    #123333
                      What engine case did you use or and did you weld it or modified it yourself?
                      Looking awesome !
                        Verry nice nice nice.:thumb
                        #123663
                          Tanta roba =)
                          Thanks for sharing your beautiful ciao monster.
                          #123664
                          Piergiorgio Pagani
                            Thank you all!
                            Engine case is Piaggio. I welded on it a Polini intake mainfold with reed valve for VESPA.
                            I welded other aluminuim addition also for change the engine case internal space and for seal the d.13 intake.
                            The cilinder is an aluminium Polini 60cc with 3 exhaust ports, 6 transfer ports and detachable aluminium exhaust mainfold d.28mm (lathe made). I changed the dimensions of all the transfer and the exhaust ports.
                            All the changes are made by myself with files and mill cutter, only the welding was made by my friend.
                            Sorry but I have only the prototype engine (bad) picture…
                            Thank you all again!
                            #123666
                            AA-T
                              Nice job! Maybe you can take some new pictures? Would love to see close-ups of the manifold.
                              You're saying you only have pictures of the prototype, does this mean there is a second version?
                              #123667
                              Piergiorgio Pagani
                                Thanks!
                                I hope to overhaul the engine in a short time… I'll take some pictures during this operation.
                                I'm saying that the engine case in this picture
                                was only for testing the correct function.
                                Subsequently I have further change the shapes of the mainfold.
