:: Piaggio Si Front fork oil question
Home Forums English General questions Piaggio Si Front fork oil question
  • #144263
    eran_k
      Hi Guys,
      I want to put new oil in my front fork,i know i need to open the drain plug and empty the oil.
      when i put the new oil in,do i fill until it comes out of the plug? and do i need to do it when the bike is on the stand )front wheel above ground)
      Thanks
      Eran
      #145851
        Exactly as you described, but there’s no need to hover you’re front wheel above ground when you fill your fork with new oil.
        #145852
        eran_k
          Bedankt friend
