:: Parmakit 50mm
Home Forums English General questions Parmakit 50mm
  • #144336
      does somebody know the Parmakit 50mm cilinder kit?
      What distance do the cilinder studs have, what stroke does it need and where to get one? 😀
      #145752
          mmmh, there is no picture on the Sprocatti side.
          I found this on Ciao cross club
          #145835
            I see they changed the cylindre to this one. Simonini copy which is a copy of a Simonini cylinder for AM6. Back in the days they were using Parmakit cylindres as you still can see on the pictures from the complete motor. Complete motor Sprocatti
            #145729
              ah, good info. Maybe I should buy that 50mm cilinder from Sprocatti.Then it should fit.
