:: pAGanO’s Bravo Special Simofolini
Home Forums Perso’s Projecten pAGanO’s Bravo Special Simofolini
15 berichten aan het bekijken - 181 tot 195 (van in totaal 213)
  • #276913
    G-no
      Wow man, the craftsmanship just keeps on amazing me! Are you planning to dyno it? Hope you film her on the track…
      #276914
      pAGanO
        For dyno I’m wait the circuit first…
        #276915
          Looking forward to see movies of “it” on the track!:worshippy
          #276916
          pAGanO
            hansieb :
            Me too ehehehheheheheh
            #276924
            SpeedDemon
              So the biggest part of the green piece is Bravo….:pest
              No man, I love it. It’s a mean, green fighting machine!
              Do you have somekind of job machining for Chip Foose ‘cause you should Dude!
              #276925
              TimoO_
                Waw great moped, looks fast, with great parts!
                The case around the malossi variomatic, does it has a bearing in it or what is it?
                Very nice! Can’t say no more
                #276926
                pAGanO
                  TimoO_ :
                  The case have a bearing…
                  See here [url]http://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?f=2&t=47097[/url]
                  #276927
                  RiPe
                    Nice!!
                    Maybe you should use such a case at the rear end too? The forces on the bearings are bigger at the clutch axle because the distance between the bearings is smaller.
                    #274486
                      Spectacular!
                      to break the balls around,
                      #274487
                        i got one word for this vespa: :worshippy
                        #276417
                        Bartjee
                          Very nice!! Looking forward to some videos!
                          #276929
                          .-{2F4OV}-.
                            Very nice Pegano! Did you welt the case to the subframe or how is it fixed? How do you unmount or multivar?
                            Why didn’t you use a 24mm carburator?
                            What’s next? Maybe you can fabricate a custom inlet (28/30mm) with 28mm Keihin or 30mm TMX kart carburator. With Stage 6 V-force AM6 reedvalve=) But I think it will be overkill for the belt:lol
                            Did you modify the malossi variator for the 13mm belt?
                            #276934
                            Loek
                              Absolutely amazing machine man :thumb
                              #276935
                              Jarco
                                .-{2F4OV}-. :
                                If you look good, you see that is is mounted in te upper side of the sub frame with 2 bolts.
                                But indeed, verry nice machine you got :thumb
                                #276830
                                Bas94
                                  hey Pagano, Awesom Machine u’ve Got i realy like it :thumb.
                                  Witch type of Jolly Moto do u got ? (original for?)
                                  Keep up the good Work :thumb
