:: pAGanO’s Bravo Special Simofolini
Home Forums Perso’s Projecten pAGanO’s Bravo Special Simofolini
15 berichten aan het bekijken - 166 tot 180 (van in totaal 213)
  • #275945
    pAGanO
      On my Bravo
      #275946
      pAGanO
        I’m now measuring for use a Malossi variator for Minarelli.
        Start gear with variator Malossi Multivar per moped
        Start gear with variator Malossi Multivar for Minarelli.
        Start gear with variator Malossi Multivar MHR for Minarelli.
        Start gear with variator Malossi Multivar Over-range for Minarelli.
        And now the final gear…
        Ed ora i rapporti finali…follow the order of those above. That for Over Range, there are two photos.
        Obviously the initial report they drive is everything closed and final report should be fully open touches against the pulley fixed.
        #275947
        .-{2F4OV}-.
          Hey Pegano!
          How do you wanna start your moped? Because there are no start segments in the minarelli clutch…
          I suppose with a 230V drill on your crank;)
          #275949
          pAGanO
            .-{2F4OV}-. :
            Hey Pegano!
            No 230V drill, but a 12V screwdriver with a little modification on the pivot.
            #275952
            RiPe
              Nice clutch, the development of your moped never stops 😀
              What size of belt do you use? (width)
              Minarelli has 16,5mm but how does that combine with the vespa malossi variator?
              Or does the 13mm belt match with the clutch?
              (I’m planning to mount a minarelli clutch on my moped too)
              #275954
                Very nice indeed!
                I have to see this on a track…
                #275955
                pAGanO
                  RiPe :
                  Well…look at this list
                  ALTEZZA = SPESSORE = DEPTH
                  The part that makes the seal is the depth.
                  The width does not serve the seal, but only to use of larger diameter pulleys.
                  We do not need a wider belt, but more depth!
                  I use the belt Malossi for now.
                  I’m looking for a belt equal to Malossi, but only 8 mm in depth.
                  I hope you can understand my bad english…
                  #275956
                  RiPe
                    Thanks for the list.
                    So I understand you’re using the original 13.4mm malossi belt for Vespa Bravo? And that works well with the clutch?
                    Maybe if you look for car belts, they have more different sizes.
                    But if the width of the belt is too small, it can’t reach the outer diameter of the clutch-pulleys. So the variation is reduced.
                    On the other side, when de belt is too wide, it can’t reach the inner diameter of the variator.
                    I’d say that’s a problem when you use a variator for a 13mm belt and a clutch for a 16,5mm belt.
                    I hope you’ll understand my English too 😛
                    #275957
                    .-{2F4OV}-.
                      Does the 12V screwdriver provides enough torque? That’s better:D
                      Look at my perso for photos of the repaired Heuvel Racing Clutch!
                      #275961
                      pAGanO
                        RiPe :
                        Well…yes, I’m using che Malossi belt for Bravo and the transmission work perfectly.
                        The car belts are no good…the good belt are use for other application.
                        No no, the Malossi belt for moped has reached the maximum outer diameter of the pulleys that the lower limit. Work perfectly!!
                        For the variator…all the variator have the same inclination (multivar, multivar mhr, multivar over-rage for minarelli) and they have the same inclination of the multivar for moped.
                        The difference is the excursion on the cranckshaft.
                        I hope you understand this table for variators malossi.
                        Spessore = Depth
                        Diametro = Diameter
                        #275962
                        pAGanO
                          .-{2F4OV}-. :
                          I use the 12v or 18v screwdriver of Wurth.
                          About your clutch…What are the screed??
                          #275963
                          RiPe
                            pAGanO :
                            Ok, I think I understand it. Thanks for the useful info :thumb
                            Good luck with the project.
                            #276910
                            pAGanO
                              Here we are, finally after 2 years of work I can finally say I finished Simofolini Bravo.
                              After many, many hours spent puzzling, to break the balls around, to drink beer while I worked on …
                              There he is!
                              [size=150]Data sheet[/size]
                              Cycling:
                              – Frame Piaggio Bravo;
                              – Fork Aprlia RS 50 from 2006 54mm;
                              – Engine Frame by Fixkin;
                              – Disk Brake 320mm;
                              – Front calliper Stage 6 for Gilera Runner;
                              – Rear shock by Sebac;
                              – Handlebars RME;
                              – Pigtail Polini;
                              – Rims Grimeca (front from a Malatugi Fifty, rear from Piaggio Bravo) 16″;
                              – Tyres Hutchinson Gp1 2.5×16″.
                              Engine:
                              – Gt Cristofolini d47,6 stroke 46;
                              – Crankshaft Simonini reed;
                              – Ignition Simonini/IDM;
                              – Crank Simonini balanced and weighted;
                              – Reed Malossi from Peugeot 103 with strip Polini;
                              – Carburator Dell’Orto Phgb 21;
                              – Air filter Stage 6;
                              – Exhaust Jolly moto;
                              – Water pump elettrica Bosch;
                              – Radiator from kart.
                              Transmission:
                              – Variator Malossi Multivar for Minarelli;
                              – Clunch Stage 6 MKII for Minarelli;
                              – Pulley for Minarelli;
                              – Flywheel clunch Polini Evolution for Minarelli;
                              – Gear Malossi for moped;
                              – Belt Malossi per moped.
                              Dashboard:
                              – Water temp PZ Racing;
                              – Exhaust temp PZ Racing;
                              – Tachometer PZ Racing.
                              I would like to thank some people who have helped me with doing this moped:
                              FixKin, Callegari, Rama racing, Raphael, AlexTeam, Checco, Smanettino, Ivano, Maurodr, MEK, Camerani, Nicola/Jolly moto, Askan90 … I hope that I remembered all …
                              Here are several links on the various processes scored:
                              [url]http://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?f=2&t=37115[/url]
                              [url]http://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?f=2&t=49494&start=0[/url]
                              [url]http://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?f=2&t=44916[/url]
                              [url]http://www.ciaocrossclub.it/root/phpBB3/viewtopic.php?f=2&t=47097[/url]
                              #276911
                                This is one mean ass machine!
                                P.s did you already drove it ?
                                #276912
                                pAGanO
                                  hansieb :
                                  [url]http://www.ciaocrossclub.it/root/discoremoto/pagano/Bravo%20Persiana/037.JPG[/url]
                                  Tnx…
                                  Yeah, I have drove…in street…LOL
                                  On 21 Sunday I’ll go to a circuit…
