:: pAGanO’s Bravo Special Simofolini
Home Forums Perso’s Projecten pAGanO’s Bravo Special Simofolini
15 berichten aan het bekijken - 151 tot 165 (van in totaal 213)
  • #275345
    just1991
      wooh ! i didnt expect that hair from you =) with that moped
      anyway your to much in the back i think… this is going ti make wheely’s all the time but it looks sooooo sweet !! like candy !
      but isnt it going to hurt your back ?
      #275346
      TimoO_
        Isn’t there a possibility to lower te front fork? This not only decreases your chance on powerwheelies, but also gives you a faster handling in corners. But it also causes a less stable moped on higher speeds, but this shouldn’t be a problem on circuit.
        #275347
        SpeedDemon
          I also think that your center of gravity is to high and at the rear, in fast corners I’m afraid your tires will give up traction. You could even this out bij lowering your front end about 5 centimers.
          And if I were you I would cut about 3 kilo’s of hair and you would need less horsepower….:D
          #266549
          TimoO_
            The high center of gravity has a positive influence because less lean is needed to cause a particular steering angle. So the chance of you’re rear wheel to brake out is less than with an low cog.
            #266547
            goedguus
              but when he lowers the front fork he could get trouble with his exaust pipe when he has a corner to te right..
              #266566
              Loek
                I think the only thing he should change is the foot steps, very nice moped!
                #275348
                SpeedDemon
                  I still think he should do his hair first… I’m cutting mine next thuesday.
                  #275149
                  MofaFreak87
                    wow wow wow and one more wow
                    the job you´ve done is crazy !
                    my full respect ^^ i wish i had also that much money to do it like you have done it !
                    verry nice ^^
                    i just saw one video till now
                    you make some more videos? i must see what comes next ^^
                    #275389
                    SpeedDemon
                      My wife just got jealous….
                      #275388
                      niceVespa
                        :thumbNICe sound:thumb
                        GTZ NV
                        #275480
                        pAGanO
                          Here a test…at the end the belt go away…
                          #275481
                            Already sounds scary, when it hits its powerband 😀
                            #275482
                            pAGanO
                              hansieb :
                              This afternoon I try the red spring on pulley and the Malossi gear.
                              Now I have the yellow spings on clutch, yellow spring on pulley and CIF/RMS gear.
                              #275486
                              SpeedDemon
                                If you would please stop placing porn on this forum, it’s a nice and descent forum let’s keep it that way!
                                :rulesI really do like the sound and the way it hit’s the powerband, keep it up!:rules
                                #275944
                                pAGanO
                                  Hi!! Because the original transmission give me some problems…I have make some change…
                                  The primary gear of a Minarelli with head of a primary gear Malossi for moped. And its covercase modify.
                                  Stage6 clutch for Minarelli modify for the clockwise movement
                                  The totaly transmission:
                                  – Primary gear of a Minarelli with head of a primary gear Malossi for moped. And its covercase modify;
                                  – Pulley Minarelli work to 100mm and modify the track pulley for work in clockwise;
                                  – Clutch Stage6 MkII for Minarelli modify;
                                  – Flyclutch Polini Evo2 for Minarelli.
                                  Original Minarelli
                                  Minarelli modify for moped
                                  Now, I weighed clutch+pulley+flyclutch+spring of my transmission and a transmission Piaggio moped:
                                  – Piaggio 2112g
                                  – My 1838g
