:: Oil mix?
Home Forums Techniek Opvoeren Oil mix?
  • #185311
    Dea_944t
      Is there any need for having more than 2% oil on tuned engines?
      I have a Polini engine with 46 mm Polini cylinder and run alkylate fuel with full synthetic oil.
      /Dea
      #203192
        I say there is no need.
        2% or 1:50 is Enough.
        Some people mix at a 1:40 ratio witch is also fine,
        But if you want a better lubrication is is better to inprove you oil.
        Aspen is a good fuel but also not nessesary. It,s ment for engines that run once in 2/3 mont,s.
        Normal fuel goes bad in about 60 day,s.
        Your setup in not an extreme setup that needs special lubrication. I see no need, but it is fun to try out castrol 747.
        Ore someting like that.
        Just for the smell of it 😉:thumb
        #203195
        Dea_944t
          Thanks!
          I used 3% during break-in the first 500 km but did have a feeling it was unnecessary to continue with.
          Main point for running Alkylate is there is less carbon build-up and soot in the engine, also more or less zero smell…
