:: Newer model Si owners – Please Help.
eran_kTopic starter
Hello to everyone
My name is Eran, Sorry i writh in english but my Dutch is limited to 2.3 words:)
I recently got a Piaggio Si, which is a 97 model, so it’s probbaly made in 1996.
Kick it has started, turn signals, front and rear stop lights.
What I found is that the electric cables from the magnetometer coils were falling apart and that caused many problems between main lights and turn lights (ignition was ok)
so i repalced all the wires with new ones, i actually come here to my question
the right side behind the plastic cover is the “Blinker” unit, the wires on my Si sphere from the magnetosphere to connect the wires that go to the front of the bike (headlight, switches ETCC.) near this “Blinker” unit but the way they are arranged there does not look correct, the have sharp bends and are very tight fit inside, i think someone in the past did a not so good job on putting the wires this way, so i ask if someone here has a photo or The “proper” way all the wiring need to be arranged.
Many thanks
Eran
You’re link doesn’t work;)
eran_kTopic starter
Sorry, i will try again, anyway it was just a picture of my Moped
FonSBijdrager
I’m not sure if you’ll find what you need, but it’s a start:
Complete service manual, with wiring diagrams: > click here <
eran_kTopic starter
Thanks Fons,
i already have this manual and it helped in understanding the wiring, but my question now is more “Cosmetic” in it’s nature, i’m trying to figure out what would be the correct way to route the wires
Thanks
Eran
