:: New Pinasco vario experiences
Piet30Topic starter
are there already some experinces with the new Pinasco variator available? :relax
I ride for more than one year and a lot of kilometers and tours. There ist not much different as a SpeedControl.
Piet30Topic starter
ok, cool.
No problems with starting the engine like with Malossi Multivar?
What weight of rolls are in the set?
Do you use also the Pinasco Spring for the clutch?
Starting is the same like the SC. I can not remeber the wights, but i don´t use them. If it is important i can wight them. But they have the same 16×13 size.
Yes i also use the spring the same time. The pressor starts same like the yellow malossi an ends like the red one.
But i get more and more problems with the spring. Now the pressure in the beginning is so low that the vario switches before the clutch enganges… so can not come on speed first.
