:: my 2 engine ciao
Home Forums Perso’s Projecten my 2 engine ciao
15 berichten aan het bekijken - 16 tot 30 (van in totaal 36)
  • #426258
      Sorry fore my very bad english:con:con
      How wil you get fuel into the highest engine?:?
      Your fuelcrane is to low for it.
      #426259
      Loek
        0,33l pet flesje met ventiel door de dop. ontluchtingsnippel in de onderkant.
        4mm benzineslang gaat perfect over het ventiel. Doe ik altijd als ik moet testen.
        Beetje creatief zijn we toch wel? 😀
        #426262
          probeer in dit topic in het Engels te reageren, is wel zo leuk voor fas
          #426263
          fas
            hi people 😉
            today i did:
            -build a second “tank” for the higher engine (you will see pics tomorrow!)
            -and much small things
            and the first start, it drive awesome, its not like you mean….
            both engines turn really high and she get a very high speed, but i didnt test it till the end today 🙁
            tomorrow you will get pictures and videos 😉
            seeya
            #426264
            reiniero
              sounds nice:)
              but how are you going to put a axhaust on the highest engine or are you going to make one yourself?
              #426265
              Loek
                Is al lang gefixt Reinier :p
                http://fabian-schoen.magix.net/
                #426267
                fas
                  here some more pics, video pherhaps tomorrow, i only can say, that both engines run und she drive very fast (do only untill 50kmh)
                  mfg
                  #426268
                    Its humor i wanna see a movie of this monster 😀
                    #426277
                    fas
                      here a video!
                      one more is uploading yet
                      http://de.youtube.com/watch?v=v_igIx2hMtE
                      #426279
                      PiNeAppLePro
                        WOw that is great 😀 GJ
                        #426282
                        fas
                          #426284
                            Awesome:D you did a good job!
                            How does it feel? Can you really feel the extra block adding power?
                            #426285
                            fas
                              yes i can 🙂 but the clutches had wrong springs into it, the engines should turn some higher before the clutch starts to give the power onto the backwheel 😉
                              but you really feel the + power!
                              cya!
                              #426286
                                fas you’re the man!
                                but how did you mount on the second pully?
                                #426289
                                fas
                                  there are 2 (hex nut?!) on the backside of the pully, you can put it on and take it away by hand 😉
