- Dit onderwerp bevat 35 reacties, 16 deelnemers, en is laatst bijgewerkt op 18 jaren, 3 maanden geleden door fas.
28 december 2007 om 01:03 #284102
hi im totaly sorry for:
-i dont am able to write in NL
-i dont know were to post this because i dont understand the board namesSORRY 😉
but i think you´ll like to see this, perhaps anybody here can do the thread into the right board…
but now to the story 😉
since 1 year i had a ciao with a 72ccm polini on a speed engine, thist summer it gets a variomatik and a technigas tek exhaust, she drives really good, but it wasnt enaugh so i think to myself how to get faster, more extreme & this for not much money!
one day i stand in my garage and saw my ciao “moped” (40kmh legal) engine and i get the idea to build a 2 engine ciao,and i did 🙂
i dont spend any money to this projekt because i had lots of ciao parts (engines/carbs and every other thing)
first i want to stay with the variomatik but its too difficult for the beginning, so i build it onto mono with an moped gearbox…
perhaps anyday i lift it up to vario, we´ll see!too much talking, here are the pic´s (its not ready but on the best way to that, think it could start tomorrow!)
http://fabian-schoen.magix.net/
(klick on “rennmofa aktuell” for the latest pics, on “meine rennciao” you can see the ciao from the beginning)have fun and do some comments please 😉
fabian28 december 2007 om 01:21 #426241wowie nicee 2 motors @ 1 frame?
how does it drive? top speed?
however the paintjob isnt the best haha.
28 december 2007 om 01:35 #426242
sjaak trekhaaknice but why do you have 2 differend size of poelies?
28 december 2007 om 01:48 #426243dat is het hem net als je het slim aanpakt.
je legt onder het onderste blok een lekker grote poulie zodat hij lekker op toeren komt.
op het bovenste blokje een dikke 70 of 80cc met ene kleine poulie.
als je met die grote poulie toeren gaat maken dus op topsnelheid gaat , geef je met het bovenste dikke blok beetj gas mee.
om op gang te komen zonder teveeelmoeite want dat lukt normaal neit mer kleine poulie.
je zorgt dat je onder helemaalop top zit.
je draait het dikke blok met kleine poulie helemaal open dat stroomt door naar top wat je normaal niet goed haalt.
en je laat het gas van het onderste blok los.28 december 2007 om 01:53 #426244
RebelZover ik weet he moeten ze beiden gelijk lopen (scheelt niet op een beetje power.)
Maar je kan niet 1 70cc pakken en 1 50cc.dan draait die 70 toch veel vaker die poulie rond slaat ie die andere snaar gewoon kapot.
28 december 2007 om 02:01 #426245
sjaak trekhaakmaakt dat blok met de grote poelie dan niet teveel overtoere?
oh nee snap het al:con
28 december 2007 om 09:02 #426246very nice fas, does it work already?
do you have a movie of it?
I moved your topic to “your own special”
28 december 2007 om 10:18 #426247hi, sorry but i can only answer the english questions 🙁
however the paintjob isnt the best haha.nice but why do you have 2 differend size of poelies?<
because the engines have different powers, the moped engine shouldnd turn as high as the speedengine
we will see how it works, i will make a first start video and some more 😉
seeya28 december 2007 om 11:40 #426248I’ve seen the pictures on nordic vespa power, looks good!except for the paint haha
Very curious about the results.
28 december 2007 om 11:42 #426249
RebelBut you can’t have 2 diffrent engines?
Because if 1 enginge has more power that poulie will go faster and the other enginge wil go way to high in “touren” so that would’t be good.
I think you should take 2 of the same kind enginges with maxed .5pk diffrence
28 december 2007 om 11:46 #426250I like the idea, perhaps I’m gonna make my own two engine ciao sometimes.
But I think I’ll use two of the same engines both with a very small puly.28 december 2007 om 12:27 #426251of je zet op iedere pully een vrijwiel.
het blok wat het snelste draait, doet dan zijn werk……….28 december 2007 om 16:51 #426255maar dan draait het snelste blok dus altijd :p hehe ken je dus net zo goed 1 blok erop doen
28 december 2007 om 16:58 #426256but if one engine is broken you still have the other one, so you have one for back up:P:D
edit : how are you going to do it with your exhaust?
28 december 2007 om 17:12 #426257Does it work? I tink not. Your smaller engine will slow down your polini engine.
