:: MoPower – Programmable Variable Timing Advance
almost ready to mount the Fresh engine en the mopower box. Did bench test the ignition and set the timing in the map equal with the real timing.
Wow this is some great news. Can you tell a bit more about the price? Curious!
Price is 120€ for the piaggio moped and vespa 4-pole stator version, and 140€ for the vespa px 6-pole stator version. Software and programmer are included. Map switch is 15€.
This could be a game changer in de Vespa world, i like to test one for Ya 😛
Got some cilinder’s lying around in desperet need for some maximum accuracy of the advance ignition point.
Would take a while but your welcome.
The price is about ride for suhs plug and play small packaging, i will await the test from Smallride and maybe order one
