:: Mijn 1969 Ciao
Home Forums Perso’s Projecten Mijn 1969 Ciao
  • Dit onderwerp bevat 19 reacties, 8 deelnemers, en is laatst bijgewerkt op 10 jaren geleden door drl.
5 berichten aan het bekijken - 16 tot 20 (van in totaal 20)
  • #498050
      Schnellspanner 😉
        Ja schnellspanner…. ich denke, das ist die Übersetzung für den Trägergurte 😀
        #498051
        Ciao1968
          drl :The license says mofa, im not sure, i never drove it.
          The toolbox is black.Today i disassembled a Bit more…unfortunately the bearing of the Front wheel is pretty bad…
          On the side covers it says Mofa as well and your frame number say Mofa also. Piet30 (Ralph) explains the differences of the early 25km/h mofa engine in the topic from his one. You can see a lot of pictures there also. It should be quite easy to determine if it’s a 25 km/h mofa engine.
          See it here:
          http://www.vespa-ciao.nl/forums.php?m=posts&q=35374&d=50
          #498055
            I’ve made some Photo’s for you, from my mofa. Here you can see the 25 kmu details:
            http://www.vespa-ciao.nl/forums.php?m=posts&q=3116&d=1950
            #498069
            drl
              Hey, thanks for all the help, its a mofa.
              Unfortunately not as good as your guys ciaos.
              I want to keep a bit of the patina, I like the used look.
