- Dit onderwerp bevat 19 reacties, 8 deelnemers, en is laatst bijgewerkt op 10 jaren geleden door drl.
27 februari 2016 om 17:58 #284687
Hello Everybody,
just bought this 1969 M9N1T, Enginenumber is 125105.
Its a first owner ciao that run the last time in 1981 so theres some stuff to do…
Can someone tell me if the engine is correct ?I need a stand and the original steering bar with the lamp holder or just a lamp holder for the actuel V-Steering Bar, maybe someone has these parts for me..
27 februari 2016 om 19:37 #497998Nice ciao, I’ve got the same:
The original steeringbar and the stand are rare and hard to find.
I am looking for a stand (in good condition) for about 1,5 year now… and I am still searching….
27 februari 2016 om 19:46 #497999Hello and welcome to this forum
Thats a nice Ciao, very special! I also think it will be really difficult to find parts for this specific model Ciao.
But anyway i wish you all the best in your search, keep us up to date
27 februari 2016 om 20:10 #498000Welcome
Nice Ciao u got there! pictures would be nice:D27 februari 2016 om 22:35 #498002In 69 also the best cars were produced!! Cool ciao 🙂
28 februari 2016 om 15:57 #498004To see if the engine is correct I need to know the frame number (by PM if you like), are you sure it is 1969 and not 1970? It looks like it already has a black tool box. The 19″ model was still available in 1970, 1971 and even a small batch in 1972. The headlamp was mounted original also this way.
It appears to be all original.
A 19″ kick-stand will be hard to find, maybe it easier to lengthen/modify a 17″ one.
drl :
Hello Everybody,just bought this 1969 M9N1T, Enginenumber is 125105.
28 februari 2016 om 16:13 #498005Hi,
its definitly a 1969, from what the tag says at least. :conFrame number is 0209056, but yeah, it has a tool box.
The lamp holder is welded to the luggage carrier and looks pretty homemade..actually I dont know if i like it like that.Also; i have a broken spoke at the rear wheel..i dont know if its possible to fix..
28 februari 2016 om 16:18 #498006I forgot to ask: is the V-Steering then also correct/original ?
3 maart 2016 om 16:19 #498021The luggage carrier appears to be welded, but it still could be the original headlight’s place, the headlight is a 1970± model so maybe it was damaged at one time.
If the framenumber is 209056 (6 digits) it is a 1969 model, the engine number appears to be off quite some numbers so I suspect it is not original.
Do you know if it is a Mofa (25km/h) engine ? What colour is the toolbox? Light grey or black?
4 maart 2016 om 20:17 #498023Yeah, i think so too, also because of the Steering bar.
Im wondering about the difference of the Enginenumber too..its quite less, maybe older?
The license says mofa, im not sure, i never drove it.
The toolbox is black.Today i disassembled a Bit more…unfortunately the bearing of the Front wheel is pretty bad…
4 maart 2016 om 20:31 #498024Maybe you can show me a pic of the correct light, light holder and steering bar?i wanted to build it up originally…
5 maart 2016 om 23:21 #498029If you look at the photo i posted here, you’ll see the original headlight, lightholder and steeringbar…
6 maart 2016 om 14:01 #498038Thanks, I found it.
I hope i can getan These Parts somewhere…8 maart 2016 om 18:37 #498048Does someone know what this is ?
8 maart 2016 om 18:50 #498049In Holland we call this “Snelbinders”
These metal things were holding the rubber belts.
