:: Mazzucchelli AMT216
Home Forums English General questions Mazzucchelli AMT216
  • #801709
    Millen
      I bought a mazzucchelli amt216 wich should be for the simonini 4 stud case right? But the problem is that the crank doesnt go in the case. Anyone has any experience with this problem?
      #801741
      Smallride
        The amt 216 is a 46mm stroke crank, is this correct for your cilinder? simonini 80.001is a 44mm stroke crankshaft. do you have a picture of the problem?
        #801745
          I have seen sombody on this forum (Piet) who has his simoninie block machined to make it fit for a 46mm crankshaft.
          He hasn,t been around for some time know.
          Here is a topic that he made:
          Piet’s Simonini 4p
          But unfortenely I cant find the topic where he machined his carter. Maybe if you Pm him, he can explane what he dit.
          Edit: I found it!
          Piet's Sprocatti EVOLUZIONE
          I hope you can do something with it.
