:: malossi springs
Home Forums English General questions malossi springs
  • #144109
    pink floyd
      Hi everyone, I’ve got some malossi clutch spring here, there painted black,yellow and white.
      Can someone tell me the order of the colours from stongest to weakest, also will a polini
      top one fit my 1970 ciao o.k?
      #145091
      noellke
        i think the black are strongest
        #145092
          from weak to strong.
          -black
          -yellow
          -white
            mmmhhh, after ma experience the yellow ones are the weakest.
            I think that the Polini Top One could fit the 70er Ciao because I drive a Proma Cirquit on my 70er Ciao and the fixing should be the same. But if you also have the 19″ wheels like I have you could get a space problem to your front wheel.
            see pics
            cu,Ralf
            #145094
            pink floyd
              Yes, i also have 19″ wheels, i didn’t think there would be enough room between the front wheel
              and the engine to fit the top one, maybe i’ll go for a proma cc, i have a tecno cc fitted at the
              moment, but no one rates that pipe very high on here! Think i’ll stick the yellow springs in first,
              see what happens, thankyou all for your help.
              Martin.
              #145095
                yes, the Tecno CC is crap compared to the Proma CC. I drive the Proma CC on a 43mm cylinder kit and it runs very good together.
                I also drive the yellow Malossi mono clutch springs in the above setup. Compared to the white and black ones they react at lower RPM’s on my engine.
                cu,Ralf
                #145099
                terrydean
                  where did you guys find the 19″ wheels? or do ciaos come stock with them in your country?
                  i’d love to get a set for my ciaociao..
                  #145100
                    They’re very rare.
                    The first few models had them.
                    I’d buy 19inch rims and get them spoked instead of searching for original ones.
                    #145101
                      yes, I have Ciao’s of build year 1968 and 1970 and both have the 19″ wheels. Think this was standard at that time. Up from 1971 there were 17″ wheels as far as I know.
                      #145111
                      terrydean
                        yeah, my 71 has 17″ers. laaaaame
                        #145129
                        pink floyd
                          Hi terrydean my U.S. friend, how are things in the states? my U.K. 1970 ciao has 19″ wheels,
                          i think the gearing must be different in the hub for 17″ models, but i maybe wrong.
