:: Malossi Remsegmenten
Home Forums Mening & ervaring Overige mening & ervaring Malossi Remsegmenten
  • #787616
    sx3-swe
      Found theese today, are they new on the market or old?
      I have ordered a set for front and rear, lets see how they perform. 🙂
      Couldn’t any info here on VCNL, any one have tested them?
      (It’s Okey if you write in Dutch, I can translate it, hence put this topic outside english section)
      Capture
      #787631
        First time I’ve seen these haha. Nice catch!
        They actually made them yellow, and you will never see them again after mounting.  :mrgreen:
        sx3-swe
          The brakes have arrived.. 🙂
          My first impression is, theese are probably the same as Polini brakes but new color and other package..
          So why would I say that?
          …Because, the casting on the rear brake says it was manufactured “06”/2006 as from reading this post, @Wilk1985 noticed the same thing with Polini ones.
          Ferodo remsegment gebruikers ervaring gevraagd?
          IMG_20190628_184654IMG_20190628_184747IMG_20190628_184759
          #788205
          sx3-swe
            I can notice that the pads are glued different from the original..
            Don’t know about Polini or Ferrodo if the are glues the same or different.
            IMG_20190701_193958IMG_20190701_1940118IMG_20190701_194257IMG_20190701_194833
            #788211
            Jochem
              WoW that looks Very nice ! 👍
              To bad you don’t see it anymore when fitted.
              are the red springs also stiffer as the orginal ones ?.
              Gr Jochem
              #788230
              Thijs_DR_Evo
                The difference in position of the friction material in relation to the carrier is interesting. I assume this is done on purpose at Malossi, which could be related to the self applying effect of brake drums. Might be you can generate more heat/friction with less effort at the handle.
                If I am not mistaken wheel rotation direction is righthanded (in the picture above), which means this is the self applying brake shoe.
