:: Malossi reed valve crankcase, worth the effort?
Home Forums English General questions Malossi reed valve crankcase, worth the effort?
  • #144371
    Coolvette
      I´m planning for a tuned SuperBravo and my eyes fell on the Malossi reed valve crankcase.
      I see the opportunity to get a good intake, better than to open the small stock intake.
      Is it worth the money to spend on these parts?
      They recommend a full round crankshaft but will it work with a stock crank too?
      I see that it will not fill the case as it should but the round cranks seems to be out of stock.
      Any opinions about that?
      #146264
        Just make sure you get your hands on the old Reedvalve crankcases. The newer ones(production dated 2010) are known for having more problems.
        Even if Malossi recommend the full round crank’s just a stock Piaggio crank would be fulfilling. It seems the whole pressure build up stories doesn’t have much practical effect on vespa carters.
        #146265
        tnerual
          why would you buy it?
          Only for the bigger carb?
          I think you should only buy this cranks combinated with the DEPS cilinders…
          I would rather consider a EVO engine?
          #146266
          Coolvette
            tnerual :
            Thanks for the input.
            I imagine the stock crankcase is a bit limited when it comes to power even with the intake opened as much as possible.
            Those aftermarket crankcases seems to flow a lot more than any modified stock part, am I wrong on that?
            I must stop at 70 cc´s as that is the true limit at the local race I will take part of next spring.
            How big is the DEPS cylinder?
            #146267
              too big for “70“`true cc the deps is like 72cc or something.
              only thing you can do then is go for a 43mm cilinder witch is aprox. 65cc
              evo engine works very good with 46 polini cilinder, massive torque and a medium rpm count. (2 valves)
              malossie rv engine is good also but needs tuning and preperation. (4 valves)
              few minors:
              – fly rubs agianst crank case
              – most crank shafts touch the crank case (witch causes jamming)1
              – needs tuning for optimal performanse
              i drove it with DR evo 43 and a 19mm carb, and it went to 10.120 rpm 😛 (88 km/h)
              but not much of torque
              #146268
              tnerual
                Exactly as Ritze sais 😉
                + there’s a big negative issue for the RV; On the base where the cylinder meets the crankcase, you only have the 2 transfers on the base, just as the original cases.. And 1 quite big port, but that is specifically for the DEPS cylinder.. So if you planned to mount a regularly used cylinder like 46,5 Malossi, or the 46 PM, you would have to mill in your brand new carters!
                BUT;
                (example); if you buy the EVO cranks, in combination with the 46 PM, the ports will match nearly perfectly, as there are already some remarkable transfer ports in the cranks, contrary to the RV.. And this is a very big plus, for me 😉
                Your choice 😉
                #146269
                piontek
                  otherwise , if you can find a Simo side inlet, you can combine it with the standard half cranckcase , so that you can use also a 1313 dell’orto carburetor.
                  In my opinion this combination should be the best.
                  The only difficulties is that you have to set up the two carburetors very well, in order to get the best throttel response.
                  #145861
                  Coolvette
                    piontek :
                    This seems to me to be a bit over the top.
                    One large carb on the side intake should do the trick.
                    I look for a Simo side inlet, perhaps I can find one and test it myself.
