:: Malossi or athena? (46)
hi yes i have the pinasco deps and there is a screw with 22mm and one with 27mm i would have the simonini calibrata with 27mm its a very good exhaust 🙂
@ Pinascodeps; Since you have this cylinder make sure you measure the diameter because the Pinasco has one with 28mm and the Malossi one with 27mm. Both the exhaust flanges are not possible to exchange betweeen cylinders. Therefor there is still some adjusting to be done.
So, a fabrizi would fit?
how can a calibrata fit, calibrata is 30mm right?
Else i guess it would be possible to make a 30mm adapter?
If you got the 28mm Fabrizi?
Keep in mind there are some exhausts which come in different diameters connection. The Simonini Calibrata is there in more options for instance.
And yes, it is possible to make a adapter. With this option any exhaust you could adept to the desired flange.
Oh ok understand now then.
The pinasco i were looking at is sold for some time ago i found out..
No one here happen to know where i can find one? 🙂 found another one here on vespa ciao but he didnt want to send it to sweden :/
maybe olliegasselt have some left pm him
