- Dit onderwerp bevat 39 reacties, 11 deelnemers, en is laatst bijgewerkt op 20 jaren geleden door .-{2F4OV}-..
19 maart 2006 om 20:46 #183506
I want to make a copy of a malossi carter with my speed engine carter and i need a picture of the malossi carter.
I want to see the engine from the cilinder angle like on this picture. Does anyone have a picture.
19 maart 2006 om 20:55 #190950[url]http://www.mijnalbum.nl/Album=BVONBX6O[/url]
Here you are!(look to the right in the menu).I’m almost ready with my own deps carter copy, made of an original carter:)
Where are you going to get your deps cilinder?
19 maart 2006 om 22:02 #190951I bought My 47mm deps cilinder from a guy here in sweden for 90 euro including shipping. It was brand new he sold his ciao before he got the cilinder so i bought it.
Thanks for the link by the way!
19 maart 2006 om 22:15 #19095247mm how many cc is that?
19 maart 2006 om 22:18 #19095375cc 🙂
19 maart 2006 om 23:56 #190954Maybe you should take a look on my own website….
The Malo engine is the one at the top-left…..;)
http://www.vespafreak.nl/vespa/enginepage.htm
Gelukkig is m'n piemel in 't Engels wél dick!20 maart 2006 om 08:38 #190956
.-{2F4OV}-.What do u mean by making a copy?
Do u take a standard carter and edit this one so it’s the same as the malo engine?
How can u do this?20 maart 2006 om 09:44 #190957.-{2F4OV}-. :
What do u mean by making a copy?Do u take a standard carter and edit this one so it’s the same as the malo engine?
How can u do this?Buy 2 or 3 fucked up aluminium cilinders.. maybe you can get em for free, since they are fucked up, melt ‘em up. Make a nice manifold (spruitstuk) of it etc. And there you go. Would be a lot of work but it IS possible I guess. Before I had mij malo I would make one myself too 😛
edit:
Be sure you know a good welder.. someone who is skilled and CAN weld aluminiumo btw.. also make sure the nicasil layers are gone before you go melt 😛 else it would be sucks to weld ‘em onto your carters
20 maart 2006 om 14:16 #190958
.-{2F4OV}-.Seems very difficult to me 😀
20 maart 2006 om 14:20 #190959‘Making a copy’ in my case only means making the cilinder fit(because i have used a piaggio carter instead of a speedengine), and the central port match with the one on the cilinder.
I’m NOT making it a reedvalve engine, dunno what millen’s plans are.
20 maart 2006 om 14:52 #190960Edjuh :
‘Making a copy’ in my case only means making the cilinder fit(because i have used a piaggio carter instead of a speedengine), and the central port match with the one on the cilinder.I’m NOT making it a reedvalve engine, dunno what millen’s plans are.
Yeah, that’s exactly what I’m planning to do aswell, not making a reedvalve or anything like that. Maybe I’ll try that some day with a fucked up engine, but not with my brand new SpeedEngine :con
Thanks iaccaloco, you website had some great pictures that’s going to be very useful for me! 🙂
Btw, since there aren’t many serious Ciao-tuners here in Sweden, I was wondering if the Malossiengine is better than Polini Evo? Cause I’ve had an Evo and planning to buy a new, maybe I should buy a Malossiengine? What do you think?
20 maart 2006 om 15:02 #190961malossi carters have a larger inlet
Gele Racefrikandel20 maart 2006 om 15:15 #190962Herr FlicK :
malossi carters have a larger inletI’ve seen that, but doesn’t it have a smaller carburator? I’ve only seen that you can buy 17 mm carburator to the Malossiengine. I don’t understand why they make the inlet larger when they have a smaller carburator? Or is it the cilider with the central port that’s making most of the difference to the Evoengine?
20 maart 2006 om 15:25 #190963The deps cilinder is i think way faster then the polini 80cc.
Dual exhaust port is real fast and compared to the 80cc polini which is i think way slower then the 80 deps.
Also at the malossi engine you can put a bigger carb on.
Check http://www.vespa-ciao.nl/forums.php?m=posts&q=2247&n=last#bottom
The biggest pro is ofcourse the better cilinder i think. If you want a deps cilinder on a evo engine you need to adjust the hole carters by making a deps port in it. At the malossi it ofcourse standard comes with 1.
If i had the money and the will i would definitly go for the malossi engine which i think you can get more HP out then then the evo engine.
It also looks like the inlet of the malossi carters is way more then evo engine.
A question ends : whats the biggest carb you can put on by adjusting the inlet-manifold (spruitstuk) were the carb is on. Is 20mm the max or you can make it 24mm ?
20 maart 2006 om 17:04 #190964Mill, if you’re planning to buy another nice engine for your Vespa……
Be sure to get yourself a Sprocatti-engine….
None of us tried it yet, but i’m véry sure…
Throw your Malossi, Simonini and Polini-engines in the recycle bin, Sprocatti is the shit!!
http://www.sprocatti-motori.com
Gelukkig is m'n piemel in 't Engels wél dick! -
