:: Malossi crankshaft
Home Forums English General questions Malossi crankshaft
15 berichten aan het bekijken - 1 tot 15 (van in totaal 17)
  • #144125
    frandecool
      #145378
      eddi
        I think this malossi crankshaft wil fit, yes.
        but there are alternatives, for example, mazuchelli..
        #145379
        Rebel
          Sure it will fit
          but if you have no good reason for it i should’t do it
          you cant drive with poulie anymore (you need to drive vario with it)
          And the (spietjes?) (crankshaftpspiel?) are about 12 euro so i rather choose a mazuchelli then
          #145380
          frandecool
            Where can i by the mazuchelli chrankchaft:)
            #145381
            frandecool
              He he i found it 😀
              #145382
              Millen
                You don’t need vario for the Malossi crankshaft, it works perfect with pully aswell, you just have to make some modifications on this part: http://mopshop.de/shop/product_info.php?cat0=441&cat1=496&cat2=1712&cat3=YWxs&products_id=1499&osCsid=e13ee0cc524b99ca6cb172b3dff9c9e6
                I see you’re from Denmark frandecool? You just have to “fila upp” (that’s swedish words, I don’t know the words in english but I hope you’ll understand since you’re from Denmark :)) the hole in the middle of that piece and it will work just fine. Just make sure you don’t “filar upp” the hole too much, and don’t make the hole round, it shall be the shape it always is, just bigger.
                Maybe it sounds kind of difficult cause I suck at explaining things, but it’s really easy.
                #145383
                Rebel
                  So you only need to make changes to the ground plate?
                  by making the hole bigger?
                  #145384
                  .-{2F4OV}-.
                    I should take the mazzuchelli with pully or the malossi and buy vario transmission;)
                    Vario is way better:thumb
                    #145385
                    Millen
                      Rebel :
                      Exactly :thumb
                      #145386
                      eddi
                        .-{2F4OV}-. :
                        Frandecool already has a variomatic transmission;) so, he can choose between both crankshafts
                        #145419
                        N0S15
                          I have a question about the Malossi MHR nut which includes with the malossi crankshaft. The one I have is torn and come loose when I drive. SO my question is if I must buy a new one from for example Mopshop, or if I can find it in a oridinary ironshop. Do somebody know?
                          #145420
                          G-no
                            you can find it in an ordinary ironshop, it’s the nut you fasten with keky nr.13 (M10?)
                            #145421
                            Rebel
                              You cant use other cranckshaft screws for it 😉 remember that becouse you will make your screwwire dead.
                              #145422
                              N0S15
                                There is a special nut for the crankshaft. I know that. But my question was if i could find a similar nut in a ordinary ironshop. But probably I can’t. It’s just that 10 € for a nut is kind of expensive.
                                #145423
                                  Yip it is, just like the “spie” it is also special
