:: Killer switch on a CDI machine, where to put it?
Home Forums English General questions Killer switch on a CDI machine, where to put it?
  • #144363
    Coolvette
      I can´t find where to put the killer switch on my machine.
      The electrical system was ruined and no cables where possible to follow.
      By looking at this chart I can´t fint it:
      I have a feeling that the red cable to the CDI unit is the one to use but how skall I use it?
      Can I ground this cable thru a NO killer switch or shall I open the loop with a NC killer switch?
      #146439
        You need to use the red one indeed 😉 I don’t really understand what you mean with the different killswitches.
        #146440
        Coolvette
          docs911 :
          NO is Normally open, NC is Normally Closed.
          Shall I cut in a lead that goes to ground if activated?
          #146441
            I would go for normally closed. Than when you use it, it would have the same use as taking the key out of the ignition from a car.
