:: Key “ignition”?
Home Forums English General questions Key “ignition”?
  • #144214
    JoQ
      Hi there, i bought a electric switch with a key. Which cable from the ignition should i cut and put the switch on. I want to use it so i can “lock” it, when its off it cant start and when its on its normal. So which cable is best to cut?
      #145019
        Do you have an electronic ignition? Then it’s the green wire 😉
        #145018
