- Dit onderwerp bevat 127 reacties, 17 deelnemers, en is laatst bijgewerkt op 2 maanden, 3 weken geleden door Daniel citta 0.5.
9 april 2020 om 21:11 #795364
I got the bike to run. Here is a video of the first start. I’m getting a lot of belt slap, but the bike is fast for the short ride I took.
7 juni 2020 om 22:07 #798495
Almost finished with this moped, still needs some carburetor tuning, and lights wired.8 juni 2020 om 16:22 #798730This ignition don’t have a lightcoil. Where you take the electric Power for Lights etc.?
8 juni 2020 om 22:41 #798746I’m going to try running the lights with led bulbs off of a drill battery, if it doesn’t last long enough I’ll get a larger battery.
9 juni 2020 om 12:57 #798752You need a longer belt too. Cause this way you loose a lot of acceleration.
9 juni 2020 om 18:15 #798759The belt is long enough it’s the wallaroo / fox belt so it’s wider than stock Vespa belt. I still need to make a spacer for the variator so the belt will sit on the variator shaft which will bring the belt to the top of the rear clutch cheeks.
10 juni 2020 om 21:57 #798842What for a CDI is the new one?
I’m curious about the results.
When the spark is also weak, maybe I can give you a tip to increase the Sparkenergy.11 juni 2020 om 12:07 #798846I’m using a 8$ cdi box from a motorized bicycle engine. I’ve read that they get erratic timing at higher rpms. I have yet to experience this but I haven’t ridden the bike much due to not having the proper size jet.
This is the cdi I’m using
Yingshop CDI Ignition Coil 49cc 50cc 60cc 66cc 70cc 80cc 2-Stroke Engines Motor Motorized Bicycle Bike ATV Quad Go Kart Moped Scooter https://www.amazon.com/dp/B019VTEFXS/ref=cm_sw_r_cp_api_i_ajG4EbEA3VYG811 juni 2020 om 22:54 #798894It looks very small. Watch out if the Cdi gets hot.
Du you have a Strobo-light? Can yoa check the timings?13 juni 2020 om 03:00 #798981The ktm box is actually smaller than the motorized bicycle cdi box you can see the exhaust old ktm box still on the subframe. I do have a timing light I need to check that next.
13 juni 2020 om 03:03 #798982
29 juli 2020 om 14:12 #800617New wheels installed on the kinetic.
5 augustus 2020 om 13:54 #800807Nice, looking great
Your projects are eye candy to me, so keep on doing so 😎TICKLING BARN7 augustus 2020 om 04:39 #800840
In the process of tuning the variators and carburetors on both the burgundy grande and kinetic. I reassembled my blue grande then snapped the crank, I’m in the process of rebuilding that engine now. I lightened the flywheel while it was apart. I don’t know how much lighter I could make it and still feel safe to ride it.
7 augustus 2020 om 09:29 #800841You got some cool projects going on man! I got a motorised bike myself at home. They are a lot of fun! You should write a how to on lightening the flywheel.
