:: Joes random builds and projects
Home Forums Perso’s Projecten Joes random builds and projects
15 berichten aan het bekijken - 31 tot 45 (van in totaal 128)
  • #791431
    Joe
      Thanks, receiving the moped of the month is awesome. Especially for the kinetic, it’s typically a bike people don’t like here in the states. Most of the time people buy them to swap the motor in a Vespa since it came with cdi ignition setup and 12 volt lights.
      #793469
      Joe
        1D8D51C7-7DC2-4662-86E1-ED78025640F84D2D3EBF-41AC-491D-9BB1-979DA108E2F7DC8FF05B-36DE-4C52-BBEE-6B846EA15191DCB624F9-A794-4479-8010-085D712371D8Here are a few photos of my current project. Vespa grande frame, forks, disk front brake, scooter clutch with the shoes flipped and a brace added, sub frame stretched for the wallaroo belt, 46mm polini cylinder, speed style case, 15mm sha carburetor, ktm 50 ignition.
        #793471
        Crullie
          Now I’m curious, a KTM 50 ignition on a Vespa cranckshaft ??
          I like to know how you did this, maybe some picture’s and info would be nice :thumb
          Like the deep red colar, great   😎
          TICKLING BARN
          #793512
          Joe
            Yeah, I cut the taper on my lathe for it to fit the crankshaft.
            17A95D12-E530-4F25-8EC5-DE75FBAE969873871A90-80AB-4A73-B7DB-E140550EA62C
            #793513
            Joe
              Here are some photos of the pipe I’ve been building for the bike.87A190DB-E1A2-49A0-895B-CBE44B82C01C8A9F07E3-8869-4692-85A6-002C0C550FFD7F1AD96E-533D-4E01-A09D-1C5CB6677C29
              #793519
              Crullie
                I could have known, of course, how to adjust an ignition, but I just had to know for sure if you really had the guts to adjust it this way 😎
                Always nice to see how 2D steel can become a 3D resonance chamber :thumb
                Allways a plessure to see your work progress, Succes !!
                TICKLING BARN
                #793520
                  I’ve seen many more people trying these type of innerrotor ignitions on a Piaggio/Citta, but sooner or later the rotor broke down or show some cracks. This might have something to do with the clutch or variator which has to be bolded on very tightly. Did you consider some strengthening of the rotor itself?
                  Tonni’s CandyRed Ciao
                  #793526
                    That red color on the Cba 😎 :thumb
                    #793529
                    Joe
                      I’ve seen the rotor used on a few builds before. It seemed to me that all the ones that cracked the builder had mounted a fan to it. I’m using a water cooled head so I won’t need a fan. But If there is a problem I can machine a steel sleeve to slide the rotor over.
                      #793531
                      Tiesman1986
                        Nice work on the clutch :mrgreen:
                        PvR has also a innerrotor with the cnc fan.
                        Screenshot_20200215-170207_Chrome
                        #793545
                          Nice work Joe,:thumb
                          What software dit you use to calculate the pipe?
                          And Itf you want a tip:
                          If you take a round piece of solid aluminium and you keep it on the back of the weld, you won,t burn through the plate.
                          #793552
                          Joe
                            I have 2 stroke wizard from buildandclick.com but for this pipe I used the specs from the Peugeot Doppler pipe. I found the dimensions on the mopedarmy.com website.
                            063E3073-5342-4C79-ACAB-A96835E88B87
                            i like the idea of using aluminum behind the weld I’ll have to try that next time.
                            #794792
                            Joe
                              44B3C33E-FBDB-4B55-A59E-25E8F00FFFB6
                              • have a very weak spark from the ktm cdi setup. I’m waiting for another cdi box hopefully that solves the issue. Here is how the bike currently sits. I also painted my rear snowflake mag for the kinetic.
                              #794793
                              Joe
                                #794794
                                Joe
                                  FBCAE569-1385-479D-AF30-21B82A9AF164
