- Dit onderwerp bevat 43 reacties, 18 deelnemers, en is laatst bijgewerkt op 15 jaren, 11 maanden geleden door Jockoballa.
17 september 2009 om 17:24 #454432
Yea, realy nice inlet. its Realy big 😮
18 september 2009 om 11:52 #45445118 september 2009 om 18:04 #454459Maby you’d better find a membranehousing and use that, fewer chances of leaking and it less work build.
Home made engine dyno21 september 2009 om 12:01 #454538Yeah, I have thought about making a housing for those membranes of my Blata rep.
This is a lot of work and I don’t know where I can get a housing like this one from abige.:(
So I have to look for a good solution.
Next time another side inlet will follow, this is just a prototype, kinda first try.
And there will follow a lot of infos and pictures of my new third and second ciao.:rules@Arvid: Nice work, how fast was your homemade sideinlet?
21 september 2009 om 16:37 #454543There are membrane housings on the market for puch but also the malossi which is used on the Simonini2007 engine.
My citta reached 97km/hours GPS with this side-inlet and a (modest) 16mm carburetor
Home made engine dyno21 september 2009 om 19:46 #454548WTF!!!!
never seen that be4 😮
22 september 2009 om 14:03 #454559@crossfreak: Thank you, but Arvid already done this, like you see it. 😉
@Arvid: Yes, but those membranekits are very expensive an it ist hard to find a housing that fits.
We will see, I am looking for some stuff.
26 oktober 2009 om 18:20 #45535126 oktober 2009 om 18:23 #455352I know that it’s fast, and it will do almost the same as the 43DR evo.
(VespaAvanti vs. 1/2)
(43KR vs. 43DR)10 april 2010 om 10:53 #460207Such a nice weather and my Ciao was full of dust..:|
Cleaned and with the new D.N. peroformance PROTOTYPE. (The serial echaust will hang higher and closer to the Ciao and will be shorter!!). After finishing that, I made a little Soundcheck.Unfortunately had no other camera here, so the quality is not so nice..
Here some impressions:
The ignition works really good.
Piaggio Vespa Ciao D.N.performance Soundcheck <—- KLICK!!
Grüße, Jocko
10 april 2010 om 11:29 #460209Motor sounds very good!
I came, I saw, and I forgot what I was doing...10 april 2010 om 21:18 #460217Great clean standard looks.. apart from the exhaust!
Wheels ALL new and shiny, look better than alloys! 😉
Super gemacht Fabian!10 april 2010 om 22:38 #460219is dat nou eindelijk zon pijp? het ziet er echt niet mooi uit. hangt veel te laag en is veel te lang!
lijkt ook nog eens op zo’n calibrata
11 april 2010 om 09:42 #460224De is wat ik zei heb. Dit pijp is de PROTOTYPE!! De recht pijp moeten minder laag en minder lang zitten.
Het is belangrijk als goed de pijp is, prestatie, PKs en de is veel better!!!!!
De demper is ook te lang, we zullen de pijp veel verbeteren en de prestatie is zeer, zeer goed!=)
2PK meer dan de Proma CC bij 60-70 km/h en veel betere ontwikeling als de Calibrata.
