:: Italjohns Bravo 1984 (English)
The wheels has arrived togheter with a broken headlight.
The good thing with the headligth is that it has a speedometer in it, and I was hoping to reuse that on my Bravo 😀
The wheels looks almost like new as well
Will this brake shoe fit?
And I forgot to install this earth point, so I had to take the engine out of the frame again :((
Yes it will fit without problems. The older models have a smaller break pad.
Thanks mate
Are you planning on painting/powdercoating these rims?
Yes, if the finish is bad after I have cleaned them, I will powder coat them.
Is that bad or good?
A pick of the clutch that was included with the wheels.
More picks of the wheels 😀
New problem. The decomp valve cable is too long :boos
That’s not a problem, when you look at my pics, you see a “Kabel nippel” on my cable.
My cable was also to long.
A local bikestore should have them.
Yes of course:D
I just cut the en off and screw on the nipple
Thanks for tip :bier
Yes almost. :pest
Good point zevenenergie.
What spark plug do I need?
