:: Is this motor with marking  D9x7 restricted to 25km/h
Home Forums English General questions Is this motor with marking  D9x7 restricted to 25km/h
  • #777496
    Nikos
      Somebody gave me this motor with electronic ignition cdi and with code D9x7 on the motor and i would like to know if it is restricted to 25km/h before i put it on.  The motor has a code starting with C242M 00*****, it also has an intake opening of 10mm and a piston pin of maybe 9 or10mm, not sure because i could not take it out.
      I managed to take out the flywheel by hands (i do not know if there is something wrong with it because i read a special tool is needed) and it is 1360 grams.
      I have google searched allover but i can not find any info except one reference in this forum where it says ” Voor mix carters geld; Lees je d9x7 = snor, d11,5×7,5 = brom. ” which after translating in english i do not understand. What does snor and brom mean and what does the code D9x7 stand for ?
      Any help please ?
      Piaggio Si
      #777497
        Snor is moustache moped, idiot name but yeah we live in Holland, and it’s made to go 25kmh,
        Brom, is a 45 kmh moped and it means to sound like a humming noise like broken transformator or something,
        I know it’s really confusing but the 9 type engine would be a snor (25) and the 11.5 would be a brom (45)
        It also means that the inlet timing is different and the crankshaft is different  a snor crank has a shorter window Of timing and it wil open and close a lot sooner then a brom engine and crank. Check krukas bewerken,, with means modifying the crankshaft
        #777498
        sx3-swe
          SOrry for borrowing the thread, is there any difference in cylinder ports or piston-pin between Snor/Brom?
          #777501
            No.The cilinders and te pistons are the same. The piston pins are for both engines mostly10 mm. But come also in 12 mm.
            #777503
            Nikos
              @ritze
              Thanks for your reply, Now it is all clear to me, so D9x7 engine is  restricted up to 25km/h which is not in my interest. By the way do you or anybody else know if the flywheel on this D9x7 engine comes off just by hands, as i did, or there might be something wrong with it and does not fit right ? Also what does D9x7 and D11,5×7,5 represent ? is it the size of something on the engine ?
              Thanks again
              Piaggio Si
              #777505
              coda
                If the flywheel has been taken off and put back but not been driven after that, then it’s possible to take it off with your hands.
                #777507
                  Porting and layout is different between snor/brom. Snor has smaller ports.
                  #777508
                    Check flywheel for any abrasion and the ” spie” has to be intact
                    Snor cilinder is different than a brom cillinder
                    #777534
                    Nikos
                      Thank you all guys for your help and quick replies. This is an excellent forum.
                      Piaggio Si
                      #778581
                      jacekniemiec
                        Hello You All !
                        maby simmilar story ..  I have two ciao mix – one run like devil and second one goes max 25 km/ h  plus is not keeping slow ‘parking’ rpm – engine is stopping after few second of  ideling. Carburator was cleaned with ultrasonic cleaner, ( I try carb from the first ciao mix – no change ) .
                        I try diffirent back weel (diffirent hubs) – also no change.
                        Can that be the the CDI ? Or something else ?
                        All the best !
                        Jacek
                        #778590
                          Hello Jacek,
                          Probably your krukaskeerring (gasket) is leaking or the engine is breathing air from somewhere.
                          To me it sounds like some gasket problem and not a problem with your CDI.
                          Please open a new thread so we can thoroughly investigate your problem,
