:: is that a Polini cylinder ?
Home Forums English General questions is that a Polini cylinder ?
  • #144102
      Hey, I bought a Speed engine with the following 46mm cylinder. Is that a Polini cylinder?
      cu,Ralf
      #145080
        Yes it is the 46mm Polini.
        #145081
        Svennoow
          Yes this is the 46mm polini 😉 PM stands for ”Polini Motori”
          Edit: haha you were just a few seconds faster tonni 😛
          #145082
            is this cylinder a racer or should I change it with a 43mm DR EVO ?
            cu,Ralf
            #145083
            PoliniCitta
              If you dont care about speed, and you like a fast boost then the polini cylinder is perfect!.
              But I should change it with the 43mm dr evo, or the 43mm pinasco that I see in your setup.
              #145084
                yes I think so, I have the feeling that the 46mm and 46,5mm cylinders are not high RPM wonder. My 43mm Pinasco is a rocket compared to my 46,5mm Malossi.
                Also I have one engine with the 43mm DR EVO what runs like hell.:bier
                cu,Ralf
                #145085
                Michel
                  It’s a cylinder for lots of torque but the topspeed is also very good.
                  It’s a Polini quality cilinder and that means good 😀
                  The DR43 is nice at topspeed but the torque is less.
                  #145086
                    aha, I think bevore I separat the engine I will try how it runs with the Polioni cylinder first. Would the top speed be in the same range like with a DR EVO in that carter and the same setup?
                    cu,Ralf
                    #145087
                      The Polini is going faster:thumb
                      #145088
                      Michel
                        Don’t give him to much fuel and it will fly 😉
                        #145089
                        barry
                          Much fuel & synthetic oil.If not….It will run too hot hot & loose perfomance very fast.The Malossi is much better & the Athena is the best.I speak for myself now.
