:: How to seal Polini H2O cylinder head
Home Forums Techniek Motorisch How to seal Polini H2O cylinder head
  • #831675
      Hey,
      I’m just putting together an Polini H2O engine.
      Maybe you can have som advice how to seal the cylinderhead durable.
      I have the original cylinder head gasket, but is this gasket long term durable against water leakage?
      Did somebody of you maybe put some rubber or copper o-rings in addition to the gasket?
      Also other ideas are welcome. 😀
      gr
      #831677
      Crullie
        Hey Ralf nice to hear from you :thumb
        Yes the gasket is specially made for water tiding use.
        Made from a aluminium mesh with a rubbery emulsive.
        For the 2 extra bolds i use copper rings under the inbus heads.
        My engine is leak-proof for almost 22years now.
        I was also sceptic so i bought a extra gasket set but it is still in the original packaging.
        P1010006
        Succes Piet 😛
        TICKLING BARN
        #831678
          Hey Crullie, thanks, I have now time to get my old half finished projects out of the corners to finalize them. :mrgreen:
          That is exacly the gasket I have for my kit.
          Only will need the two copper rings , perfect.
          #831680
          Crullie
            Your Welcome 😉
            TICKLING BARN
